Need To Re-Attach Rearview Mirror...Type Of Glue?
While removing my dashboard for reupholstering...I inadvertently knocked off the rearview mirror - which is perfectly intact with its circular mounting flange. What's left on the windshield is a circular patch of hardened glue.
So...my thought is to first use that glue-patch to draw a circle with a Sharpie marker, then remove the patch with a razor blade.
Finally, I'll use a drop of glue to re-affix the mirror.
Question - what type of glue? I've got a fresh bottle of Gorilla brand Super Glue, which I'm guessing would work fine - but is there some other type I should use instead?
And does the overall process which I've described above sound OK?
(btw...the dash came out great. Not perfect mind you...but great!)
Old 09-02-2024, 12:19 PM
Mark it on the outside before scraping. They make special glue for attaching rearview mirrors. Check your local auto parts store.
Early '85
Old 09-02-2024, 01:27 PM
You might just let a local glass shop do it, not much more than the cost of the "kit" Last time I had it done.
Old 09-03-2024, 09:10 PM
I used superglue, not sure if mirror mount adhesive has any more mojo. Maybe get some superglue gel?
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 09-04-2024, 04:14 AM
I think I paid about 5 bucks for a tiny tube of the right stuff for that. maybe its superglue.
i got 2 new side mirrors too , they both let loose so you could check those or if they fall they will break.
I dont see a way to clamp it it must be a type of superglue to dry that fast, how long can you hold your arms up for ? ;-)
Old 09-04-2024, 02:06 PM
Put this guy on the case:
Or use a pillow, a boot and a scrap piece of wood. Whatever works.
1987 928S4
1992 968 cabrio
Old 09-04-2024, 04:18 PM
garfield might actually work lol ;-)
If you dont have enough cans of "stuff" around your shop you can go buy a can of superglue accelerator / catalyst
if the stuff is simply superglue gel , probably is, then its one more product you probably don't need. its a good question for a guy that works in a glass shop.
there sure are a lot of little bottles of "stuff" in this world, so many are simply unnecessary pollution.
Old 09-05-2024, 09:36 AM
Permatex® Rearview Mirror Adhesive Kit
The two-part adhesive that permanently bonds mirror buttons to windshields. Achieve handling strength in seconds, and mirror mounting strength in 30 minutes.
Old 09-05-2024, 03:39 PM
Yep...I used the Permatex kit with good success. Thanks for the input folks!
Old 09-06-2024, 03:38 AM
