Kirby2's Avatar
Engine loads up and backfires
I have posted before, usually answers say check vacume lines.. they are OK.
When the car backfires(like a hickup, sometimes it goes dead...wait a while and it starts again.
Fuel additives like techroline seem to help, short term. I can't believe I am the only one with this problem. HELP!
Old 07-02-2003, 11:39 AM
AFJuvat's Avatar
Crystal ball is out for polishing this week.
Please state year and model
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-02-2003, 12:14 PM
Kirby2's Avatar
1986 N/A Manual 944, aftermarket header, k&n drop in.
03 Silver PT Turbo - Ours
86 White 951 - His
86 White 944 Manual - Hers
98 C-4 Sons
86 Gold 944 Auto - Sons
84 Maroon 944 Auto - salvaged
78 Yellow 924 - found a new home
Old 07-02-2003, 12:19 PM
AFJuvat's Avatar
OK, need some more information.
When does the car backfire? Engine hot?, Cold? after running engine hard, daily driving?
Can you reproduce the problem consistantly?
What kind of gasoline are you putting in it?
How does the car run when it isn't backfiring?
Any other modifications to the car?
When was the last tune up? cap, rotor, plugs, wires, air and fuel filter?
AFJuvat
Old 07-02-2003, 12:46 PM
Kirby2's Avatar
In List order:
Happens hot and cold in daily around town driving.
Happens infrequently, but once started (if no fuel aditive) gets more often.
Using Mobil Prem (91 oct)
Other than backfire runs smoothly(few misses), it does stumble as a prelude to the hickup though.
Ignition is A-1 new plugs,new coil, clean cap and rotor, new wires.
filter K&N (clean), new (1 month)fuel filter.
86 White 951 - His
98 C-4 Sons
Old 07-02-2003, 01:40 PM
Kirby2's Avatar
Also: the plugs are clean - no scaling or carbon buildup.
86 White 951 - His
98 C-4 Sons
Old 07-02-2003, 01:43 PM
Scott R's Avatar
Maybe a weak or broken AFM causing the load up?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-02-2003, 02:23 PM
Kirby2's Avatar
What is your experience with rebuilt air flow meters? They are about 1/2 the price of a new unit.
86 White 951 - His
98 C-4 Sons
Old 07-02-2003, 05:43 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Take a look at FRwilks site.
If you pop the black cover you will see how this gizmo work..... You can sometimes make a temporary fix. At least it will allow you to test to see if it is the AF.
I am not sure how you could test for a weak AFM spring ... but a bad AFM would explain your intermittent backfires.
I would suggest you look for cracks in the intake side hoses as well. AN intake leak will definitely cause backfires....... ask me how I know!!!!
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 07-02-2003, 05:47 PM
