TNT25169's Avatar
Send a message via AIM to TNT25169
MSD 6 AL (where at?)
I was wondering if anyone has installed an MSD 6 AL ignition box into their N/A 944?
If so, where did you put the box and were you pleased with the results from it? I need ot buy a blaster 2 ignition coil and I was thinking new plugs might help.
Thanks for the help.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 07-09-2003, 04:41 PM
Crippler's Avatar
I recently added a MSD to my car. I stuck it in by the battery, it was a tight fit.
As far as power increase I can't really tell you because I added a turbo at the same time. It seems to work alright though.
1984 - Porsche 944
1994 Grand Cherokee
6inch Lift, 33" TSL'S
Old 07-09-2003, 08:40 PM
I'd like to see a before & after dyno-comparisoin of any ignition upgrades on these cars.
Old 07-12-2003, 12:35 AM
TNT25169's Avatar
I was thinking on the strut tower right next to the cam tower but that would be a tight fit and it mihgt get real hot.
www.apartabove.com
Old 07-12-2003, 08:59 AM
Also keep it as far away from the DME as possible...
Old 07-12-2003, 09:43 AM
