Searching for an Accordion Style Rubber Shift Boot
Does anyone have this style shift boot they would be willing to sell? Or does anyone know what the product name is / what model it came on / where I can get one?
It's an accordion style rubber shift boot (for ref if the image link doesn't work)
Old 07-03-2025, 09:04 AM
Not a factory part...
I did a google search on "accordion style shift boot" and came up with a lot of hits.
Good luck, George Beuselinck
Old 07-04-2025, 09:43 AM
Legit Salvage's Avatar
Early-mid 80's RX-7's came with the accordion type... not sure if they'd fit. If you're good at that sort of thing, you could probably design and 3d print a trim ring that would work with it.
1979 924 NA - The Midlife Crisis
Old 07-05-2025, 08:35 AM
if you can write or download the file you can print rubber parts or send them to a place that can.
https://all3dp.com/2/3d-print-rubber-is-rubber-3d-printing-possible/
it seems likely a boot from some other car could be adapted. Id look in a wrecker if there are any naear you these days. many of the makers puut an end to auto parts recycling by using lots of proprietary parts and changing their design frequently , this is unfortunately not beneficial to the environmet or the consumer's personal economics.
Old 07-07-2025, 11:43 AM
924RACR's Avatar
That looks like the boot from an early 4-speed 924...
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 07-08-2025, 04:33 AM
Politically Incorrect
onZedge's Avatar
924RACR is correct: 477711271A
Edek
'87 924S
'91 535i
Old 07-13-2025, 12:10 PM
