afx afx is offline
afx's Avatar
Send a message via ICQ to afx
Need some quick help, car wont start
I am over at my friends house, I tried to leave and the car would not go.
car started alright, but would bog when I tried to give it gas and move. Then it would eventually not even start when I tried it
I then tried jumping the DME relay and that will allow the car to start and run, but, like before, when I gave it gas it will just bog down. It also runs pretty rough while it is running.
Any ideas on what to check?
85.5 Red 944
Http://members.rennlist.com/afx
Old 07-04-2003, 08:01 AM
TSNAPCRACKLEPOP's Avatar
fuel? pressure?
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 07-04-2003, 08:06 AM
afx afx is offline
afx's Avatar
It seems like the fuel is coming, I can hear the pump come on when I jumper the fuel pump on. I can smell the fuel also.
I am wondering if it has to something to do with it being quite wet out.
85.5 Red 944
Old 07-04-2003, 08:10 AM
cracked cap? look inside, alcohol wipe will dry it inside
Old 07-04-2003, 08:48 AM
afx afx is offline
afx's Avatar
Cap looks alright. I am thinking that it may have something to do with the fuel. When I have been starting the car it will idle pretty well, (I just cant give it any gas or it will bog down) but when I just let it sit there and idle it will just slowly get worse and worse. Maybe it is just loosing the fuel pressure.
85.5 Red 944
Old 07-04-2003, 08:57 AM
check tailpipe for obstruction, apple, oranges, especially if your friend is a new ladyfriend.
Old 07-04-2003, 10:03 AM
MrPants's Avatar
can you describe what you mean by bog down?
is it stalling when you give it gas?
84 944 Non Alcoholic
Old 07-04-2003, 11:11 AM
afx afx is offline
afx's Avatar
Yes, it will just drop in the RPMs when I give it gas. It seems like when I open the throttle and let the air in, it just doesn't have enough fuel to sustain the idle?
I have just let it sit for about 2 hours. When I started it, it ran fine for about 2 minutes. I was able to drive it and everything, then it just started getting slowly worse over those 2 minutes, and I was unable to give it gas anymore.
85.5 Red 944
Old 07-04-2003, 11:18 AM
fuel filter?
Old 07-04-2003, 11:54 AM
afx afx is offline
afx's Avatar
Over on the other boards someone suggested that it could be the coil. I am going to try throwing a new one in and see if that helps out.
85.5 Red 944
Old 07-04-2003, 12:02 PM
afx afx is offline
afx's Avatar
I have also not changed the fuel filter and I do not know when that was last done, so I am sure that would be a good idea also.
85.5 Red 944
Old 07-04-2003, 12:03 PM
yeah...could be...
also, what happens if you disconnect the O2 sensor?
could be a temp sensor that thinks the engine is cold even when it's warmed up
wiggle the Thottle Position Switch and Air Flow Meter connections in case one has gone flakey...
check vacuum tubes and the big AFM boot to the intake in case of leaks
Tom
Early '85 944
Old 07-04-2003, 12:07 PM
afx afx is offline
afx's Avatar
The O2 sensor has been disconnected for a while (couple months) so I dont think that is it.
I will go out and try messing with the TPS and AFM connections
85.5 Red 944
Old 07-04-2003, 12:09 PM
used any injector cleaner lately?
Old 07-04-2003, 12:25 PM
afx afx is offline
afx's Avatar
No i have not. If the coil does not work I am going to have to get my car towed home. When I get it there, I will probably check everything over in the fuel system.
85.5 Red 944
Old 07-04-2003, 12:29 PM
doubt it's the coil
hmmm...why was the O2 disconnected?
Tom
Early '85 944
Old 07-04-2003, 12:32 PM
Roger Hall's Avatar
Is the car running rich? Black smoke comming from exhaust? Does the exhaust smell like gas?
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 07-04-2003, 01:52 PM
afx afx is offline
afx's Avatar
The O2 sensor was disconnected because it was not functioning correctly, it would cause the car to miss at abour 4000 Rpms while under partial throttle. I have a new one, I just need to put it in.
The car is runing a little bit rich, but no more than it usually did. It does not smell all the much like it is getting too much fuel.
I got a new coil, and still no go.
Heres a recap of where I am at:
When the DME realy is jumped the car will start and run, but it is pretty rough.
I can give it some gas and it will function normally for about 30 seconds, then it will start to get rough and bog when I press the gas and almost die.
After a bit (60 seconds or so) it the idle will get worse and worse till the car pretty much dies.
85.5 Red 944
Old 07-04-2003, 02:41 PM
Roger Hall's Avatar
I was thinking the car was runnig rich. Try checking the air intake system.
Roger Hall
81 924 N/A
Old 07-04-2003, 03:12 PM
Originally posted by carsontc
the Thottle Position Switch and Air Flow Meter ... one has gone flakey...
I'm betting on the TPS...
btw...the O2 sensor you disconnected might have been masking the real problem
Tom
Early '85 944
Old 07-04-2003, 05:11 PM
