Pike's Avatar
Location: Redmond WA Can anyone help me with my snorkle mod?
Getting the instruments out.
_ I got my new Tach today, but I can't get in to replace it. I have the Steering Wheel, switches, and the hex bolt out. I can't seem to be able to remove the plastic parts. How do you get either just them or the whole aluminum thing and the ignition out?
'77 924 - Metallic Blue - enlarged TB/ intake
'99 Specialized HardRock - Blue/Silver - Jett C Shocks - Cat Eye Velo computer
If it ain't broken, drive it until something is.
Have you spent quality time with your Engine Gnome lately?
Defend Your Joy
Old 07-14-2003, 08:30 PM
I hate to post this, but here goes:
I VERY CAREFULLY worked a flat head screw driver behind one side and wiggled a bit until I could jam a rag in there, then worked the other side a bit.
The major concern here is that you not pull hard or bend the plastic frame (that which looks aluminum - hey, maybe it IS aluminum, but it bends like plastic). If you pull hard, you run the risk of pulling the electric cables and or the speedo cable.
It's a brut force equation of slow wiggling.
Yeah, I love that sentance.
Good luck - feel free to email me with more questions - I've done this way too many times on my early 944, which I think should be essentially the same as the 924 instrument cluster
Jake
1983 Euro 944 (Mine)
2000 BMW 323i (Hers)
1997 Sentra (unclaimed!)
Old 07-15-2003, 06:02 AM
http://tech.rennlist.com/924_944/porsche944dashremovalinstallation.pdf
Try there it might help
Sorry only just noticed - you got an 924
Old 07-15-2003, 06:43 AM
Pike's Avatar
_ Gave up on removing the console. Seems my car is different from even most 924s. I replaced the bulbs in the spedo and installed the tach. without out removing the instrument cluster. I am very sore now(hanging upsidedown in the driver's seat playing with little teeny wires), but at least I can tell what my redline and speed (at night) are. $45 for a working, stock, EDO tach. is not to bad. The same yard has 924T and 944 instruments too. Thanks for all of the advice!
Defend Your Joy
Old 07-15-2003, 11:21 AM
