Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Post " Oxygen sensor "
Do somebody knows what brand are this sensors or if any model of VW have the same or compatible ?
1972 914 v6
1974 914 2180cc 916 Look
1984 944 Auto
550 spyder (replica)
My Page
Old 03-22-2001, 03:22 PM
Post
They are Bosch and you can buy kind of a universal with the correct number of wires, 2, 3, or 4.
drew1
Old 03-22-2001, 06:38 PM
Post
thanks
Can you give more explanation.
Eduadro
Old 03-22-2001, 07:06 PM
Post
Eduardo,
I was wrong about the number of wires. When I said 2, it should be one.
The universal O2 sensors have one wire which is usually black for the signal. The other wires are for a heater to allow the sensor to come on quicker. On Porsche this wire would be green. On most universal sensors rhe heater wires are gray, I think. The 4 wire sensor also has a signal ground. I haven't seen a Porsche with these.
The universal sensors don't have the right connector for a Porsche. This means doing some cutting & splicing or better soldering.
I don't know if some of the VW O2 sensors use the same connector as Porsche.
drew1
Old 03-27-2001, 07:37 PM
Rollins's Avatar
Send a message via ICQ to Rollins Send a message via AIM to Rollins
Post
When I had mine replaced my mechanic took a ford sensor and soldered it to the original Porsche harness. It worked great and cost like 35 bucks.
Old 03-27-2001, 07:52 PM
Post
I paid $75 for the correct one for my car from Vertex, however, my mechanic said I waisted my money, as the universal Bosch sensor is the same thing....The universal is around $30 and is also available from Vertex...Cus
Old 03-28-2001, 03:50 AM
