Trying to find a part
Well my car is leaking from the front of the crankcase its right at the bottem of the belt cover right above the oil pan seal where the oil pump is. Exactly what seals (part # and names) do i need. I cant tell from any of the pictures ive seen and I cant get at it without taking off the belt and that lower pulley. I dont want to buy the whole seal kit because the rest of the seals were done and that one wasnt done because the PO couldnt get the pulley off of it. What happens if i run into the same problem? What parts should I get for this repair? Dont worry im planning on changing the belt even though its maybe ...10k old.
-2002.5 GTI VR6 24V 6SPD -Kalahari Beige 89 Porsche 944S2 -87 VW GTI 1.8 16v -2007 Ford PIMP(free)star ...company car.... -1999.5 Jetta VR6 |
Go to Pelican Parts and buy the front crankshaft seal. You will need a flywheel lock, a min. 1/2" breaker bar with I beleive is a 24mm or a 15/16" socket. You will need oil pump o-ring and a tourqe wrench capable of 150 lbs. You will need to remove all of the belts, sprockets and pullys as well as the back half of the belt cover. You will also need a belt tensioner and a balance shaft sprocket wrench.
When you get the pully nut of the pully should slide off the shaft. Good luck
Terry R. 1988 944 NA AT Alpine White 1987 944 NA AT Stone Grey 1987 944 NA 5 Speed Stone Grey 1987 944 S 5 Speed Triple Black |
I forgot to mention that I have done the job three times and each time on the first attempt I have screwed up the seal. So the last time I ordered two seals and sure enough screwed up the first one.
Also the job is a lot easier if you pull the cooling fans.
thanks brotha
wait ...pelican only sells the the seal in a kit ...and its like 80 ...how am i supposed to order 2? im NOT paying 160.
-2002.5 GTI VR6 24V 6SPD -Kalahari Beige 89 Porsche 944S2 -87 VW GTI 1.8 16v -2007 Ford PIMP(free)star ...company car.... -1999.5 Jetta VR6 Last edited by TheCooler; 07-25-2003 at 07:50 PM.. |
order a ruined seal, they are probably are free, then you save the time and expense of ruining a good one. then just carefully install the good one!
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Certified Rennwerker
Here you go!!!! Crankshaft seal # 999 113 331 40 around 10 bucks. Go to www.*************** you can get the individual seals there. Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
