ruechaos's Avatar
Where can I get a flywheel position sensor?
I checked Pelican and the "other" big online Porsche store, but neither seem to carry it.
Thanks for any help!
-Tony
Old 07-27-2003, 02:24 PM
dunno what you would need it for if it's the Timing Mark Sender for TDC you are talking about...I thought it was just for dealer service use
you have an 84 engine with a late 8v AFM & DME true ?
Tom
Early '85 944
Old 07-27-2003, 02:49 PM
ruechaos's Avatar
Yes. Early engine, late brain. I need the two sensors that plug into the bellhousing. One of them counts the number of teeth on the flywheel to get a RPM reading and the other one reads reads a small magnet that tells the computer where TDC is.
Hope that clears it up a little bit more! Thanks!
-Tony
'84NA Engine, '87NA Brain/AFM/wiring
harness, all in an '87S Body....AND IT
RUNS!!! kinda...
Old 07-27-2003, 03:01 PM
Tony, if your engine starts easily hot or cold and runs there's probably is nothing wrong with the reference sensor or the speed sensor...unless you know there are damaged, or have a weird intermittent starting problem or they are not ajusted at .8mm
I'm pretty sure they're all the same on the 944/NA/turbo/S so real common at a wrecking yard or eBay for less then $30 or new for $120
easy to test too...with an ohm meter (multimeter) across 2 of the 3 pins you should measure around 950 to 1050 ohms (give or take)...more info at:
http://www.clarks-garage.com/shop-manual/ign-02.htm
also a lot of discussion about this in a long ‘no start’ post at:
http://forums.rennlist.com/rennforums/showthread.php?s=&threadid=79790&perpage=15&pagenumber=1
Tom
Early '85 944
Old 07-27-2003, 04:02 PM
SoCal Driver's Avatar
And please add your car's year and model and transmission type to your sigiture line in your Personal Preferences.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-27-2003, 04:10 PM
JH924S's Avatar
Send a message via AIM to JH924S
so if these sensors are not exactly .8mm the car will almost def not start?
1987 924S black on black , does it get any better?
Old 07-27-2003, 04:57 PM
