944 speedometer problem
My 85 1/2 944 with only 22,000 original miles had the speedometer just quit. It is not recording any additional accumulation in the mileage. Where do I start in checking for this problem? I'm new to the forum and don't know alot about 944's. I had one brand new in 1984 which I sold years ago. I found this low mileage car(Red with black interior/manual) around two years ago. Appreciate any help on this matter.
Kelly
Old 07-15-2007, 07:22 PM
Send a message via Yahoo to bobp53916
More than likely the odometer gear...
http://www.clarks-garage.com/
Under the garage manual go to odometer repair. Tons of infomation there...
1985 944 N/A
1992 Formula Firebird (sold)
1997 Sebring LXI
1998 Ford Expedition
1983 944 (parted out) 1979 924 Turbo (sold)
Old 07-15-2007, 07:49 PM
Send a message via AIM to Icey1174
The odometer gear shouldn't affect the spedo though, should it?
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 07-15-2007, 08:58 PM
I assumed meant odometer because of the mention that it doesnt accumulate mileage...Does the speedometer still work or is it the odometer that quit working? If it's just the odometer then it would be the gear. If the speedometer doesnt work either then I would think it would be in the cable itself...
Bob
1985 944 N/A
1997 Sebring LXI
Old 07-15-2007, 09:34 PM
Misunderstood User
It could be the speedo too. I had that problem a few years ago. Unfortunately my cable was fine. The speedo cost me $250 to repair.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 07-16-2007, 05:05 AM
FYI: Unless you owed the car for it's entire life I would not use the odometer as an accurate gauge. These cars have so many problems and design flaws which "turn off" the odometer that you will never know for sure what the real mileage is. Look the car over well and buyer be ware. I'm sure your car is in real good shape. With 22,000 miles it should look pretty much brand new. But if the odometer broke on you then odds are pretty good it may have happened before with the PO.
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 07-16-2007, 06:44 AM
The speed and the mileage both don't work. We plan to look it over tonight. Thanks for all the replies.
Kelly
Old 07-16-2007, 05:45 PM
Spievy's Avatar
Maybe lack of power to the speedo cluster.
1975 - 914 1.8L Dual Weber 40's & MSD Ignition
1986 - 944 2.5L (SOLD)
Old 07-16-2007, 05:53 PM
Spievy's Avatar
just thought of something... does the trip zero when you push the vent button? if not I would think it would be a power issue.
Old 07-16-2007, 05:55 PM
Not a power issue. I tried the trip and it went back to zero. As per the cable, I can't find it in the manual(clarks garage) to check it. Can you help me out on it? Plan to pull dash to check on speedo gear.
Old 07-16-2007, 07:05 PM
Eldorado's Avatar
85.5 didn't have a cable i dont think... i think it was run off of electrical impulses from a sensor on the transmission.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 07-16-2007, 07:10 PM
Spievy's Avatar
no cable, all electronic
Old 07-16-2007, 09:32 PM
My bad, didn't realize they weren't cable operated. They must have changed that in 85.5 because my 85 still has the cable...
1985 944 N/A
1997 Sebring LXI
Old 07-16-2007, 09:35 PM
Do I need to check the sensor and not worry about the dash gear?
Old 07-17-2007, 07:24 AM
Spievy's Avatar
I would say take a look at the sensor, especially since neither speedo or odo work.
Old 07-17-2007, 08:44 AM
