as i said in my last post (the one about not overheating anymore) my car got quite a bit banged up, besides the dent and missing paint along the whole drivers side and a broken reflector and tail light the only other thing that i can tell is wrong with it by looking at it, checked under car and under hood ect., besides bent rims, is that my passanger side wheel is pointed strait in my driveway and my drivers side is pointed to the left. whats wrong with it?
oh yeah another problem that i found... my left side really hurts...
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
< ----- Didn't read your other post.
Power steering? Sounds like the rack could be screwed up.
Jack 86 Red 951 - Turbo Twists, otherwise stock for now 83 Black 944 w/86 951 front end - still down and out, but coming back slowly. 02 Altima SE 3.5 - grocery go-getter 00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi |
Bent tie rod?
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
dont drive the car anywhere!!!!
alignment is definately off. could have damaged tie rod, bearing, hub etc. its probably dead. financially. are you getting any insurance money? if so, just try to buy another car.
84 944 Non Alcoholic Last edited by MrPants; 08-19-2003 at 02:30 AM.. |
I'd say bent/twisted A arm, bent tie rod, and/or ruined ball joints inner and outer. I didn't read your other post, nor am I going to. Don't drive the car. If not for a litigious reason, then merely financial: Your tires will wear out very, very quickly. That 20 mi. you drove easily wroded 5-10k miles from it's life. That's bad.
If you don't know what you are doing, even if you think you do (I'm not hucking stones here, I'm just sayin") you run a serious risk of damage to property (yours/thiers), limb (anyone's), or life (prolly not yours, but someone's, and that too, is bad). Roger, I like the duct tape sig the best so far.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
