timing prob????
Hi all, new user here.
Anyone ever had this prob.??? I have an 84 non turbo, since i bought it it has always made a bit of a funny graunchy/grinding noise when the engine fires when i start it......its as if the engine and starter motor are fighting a little (you know that grindy noise that starter motor teeth make?....well it sounds a little like that).
The engine turns and runs ok its just when it fires that this sound happens. Was wondering if timing is too advanced but is`nt this electronically controlled??
Any thoughts???
thanks guys
Mark
Old 09-03-2003, 10:27 AM
SoCal Driver's Avatar
Fix the starter. Timing is fixed by the electronics, the DME.
How long has it been since the timing and balance shaft belts have been replaced?
If you don't know replace them now!
If you do know replace them now!
Other wise replace them NOW!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-03-2003, 10:55 AM
Fix the starter????? what exactly do you mean???
Belts were done last year......why should i do them again???
cheers
Mark
Old 09-03-2003, 11:02 AM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
this noise just started on mine, i was thinking it was the car saying "hey you i need new belts now or else!!!"
does it sorta sound like you held the key a bit too long but not quite and you know you didnt? if so thats whats mine starting to do... but only everyone once and a while.
know what it is exactly socal? i like hearing the tech stuff, i may not need to know exactly what it is but it makes me feel better:-)
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 09-03-2003, 11:21 AM
yeah thats what it sounds like - like you held the key a bit too long.....just as it fires its a short grindy noise. Not a smooth firing at all
If you know what it is socal let us know
Old 09-03-2003, 11:26 AM
How does my starter work in 100 words or less:
The ignition key triggers the solenoid (electromagnent) to pull the bendix into the teeth on the flyhwheel closeing the high current circuit to the motor.
The motor spins the flywheel through the bendix to start the engine.
Letting off the "start" possition of the key the solenoid is turned off opening the high current circuit to the starter motor.
The soleniod spring and the bendix spring pulls the bendix off of the teeth on the flywheel.
All of this is supposed to happen quite unobtrusively. You start to get noises from the starter then it's parts have worn too much.
Getting a rebuilt starter from Pep Boys is NOT a good idea. Find a local rebuilder where you can talk one on one with the owner and you will get a good rebuild 99% of the time.
Old 09-03-2003, 02:26 PM
As to timing belts:
We get new owners here all the time that say the PO just did the timing belt before they bought it.
Then two, three weeks later the crying starts as their timing belt or twin cam drive chain breaks causing thousands of dollars in repairs.
Most of us have found Pelican because we were/are having problems with our cars. We figure out the repairs and share these insights here.
You have to take the lumps as well as the kudos.
Old 09-03-2003, 02:55 PM
Baza's Avatar
Well said SoCal.
Always start with the cheapest option first
83 NA Guards Red ( Home at last)
2011 Triumph America
Old 09-03-2003, 11:06 PM
I didnt say new owner i said new user. Belts were done while i owned the car
Old 09-04-2003, 06:31 AM
vott does ziss do?
ronin's Avatar
sorry, 104 words. try again (yeah, leave it to me to actually count them)
Old 09-07-2003, 01:44 PM
Recount it!
Old 09-07-2003, 04:27 PM
vott does ziss do?
ronin's Avatar
LOL, o.k. let's see...
Old 09-07-2003, 10:00 PM
vott does ziss do?
ronin's Avatar
WOW, pared it down to exactly 100!! you have just received the editor of the year award!
Old 09-07-2003, 10:05 PM
vott does ziss do?
ronin's Avatar
... and believe me, checking that one was no mean feat for me as I've already had a few rum-and-cokes this evening (I'm out of good wine)
how dry I am...
Old 09-07-2003, 10:07 PM
