Back Up Lights not working
I just found out my back up lights do not work. No idea when this happened (was since last year's inspection). I recently had the clutch replaced. The bulbs do work (yes, I tried this first!). What else could be causing this problem and how can I fix it?
Runnin'On
1984 Porsche 944
Guards Red
Timing Belt Changed 2004!
Old 09-04-2003, 06:12 PM
bearone2's Avatar
fuse
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 09-04-2003, 08:18 PM
bearone2's Avatar
check the fuse
Old 09-04-2003, 08:19 PM
We checked the fuse and that also works. Any other ideas? There are four bulbs in the back assembly (blinker, running light, brake light and back-up light), only the back up light is not working. Could it be the contact with the transmission? The clutch was recently worked on. If it is this, how can I fix it?
Runnin'On
1984 Porsche 944
Guards Red
Old 09-05-2003, 05:15 AM
Iam sure there is a switch - have you checked the switch yet??? Maybe the wires came loose when the clutch was replaced.
Switch i believe is located on top of the tranny.
Old 09-05-2003, 05:30 AM
pearldrum's Avatar
Send a message via AIM to pearldrum
Yeah check the switch. Mine don't work either, I'm going to check it when I do my clutch later this month.
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 09-05-2003, 07:00 AM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
Hi ,
I've had an ongoing situation with my reverse lights also. Can I add to this by suggesting to remove the bulbs, and clean the lamp socket thoroughly with an abrasive type of instrument. I seem to constantly buil up corrision on the insides of all of my rear contact points due to moisture leakage there. Hope this works, good luck..
Frank B
My car is naughty
Old 09-05-2003, 01:06 PM
