hardflex's Avatar
how long should it take to remove Cyl Head
Hello Everyone, a 914 owner here expanding his horizons
I've taken on revival of my Bros. 86 944. it's got a broken timing belt, so i'm wondering how long it should take to remove the head,? I've done lot's of mechanical stuff, just not on a 944.
Is 3 hours about right, or is that in my dreams?
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 09-10-2003, 07:47 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Sounds about right..... as long as nothing goes wrong....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-10-2003, 08:01 PM
hardflex's Avatar
if something can go wrong, it will.
oh well, might as well get on with it. ;-)
Old 09-10-2003, 10:11 PM
more than plenty of time, I think I have it down to around 1-1/2. here's a couple of tips: spray a penetrating oil ahead of time on the exhaust manifold studs/nuts and also the manifold to catalytic converter bolts/and studs. Leave the manifold attached to the cylinder head and remove after the whole thing is out. don't use a ball style allen to remove the allen bolts inside of the camhousing; it will break and be nearly impossible to remove. (I hate jobs that are passed on from someone else!) don't waste time putting the engine to TDC before tearing it down. It's easily achieved with the head off for re-installation. Drain the coolant as much as possible from the radiator, lower radiator hose, side of engine block, and even once you remove the upper filler neck from the cyl. head use a punch or screwdriver to punch a hole in the head gskt to help the coolant drain to below. These are all things to keep the mess to a minimum when lifting the head off. there are plenty of more things so once you get started or when you're ready to put things back together, just ask.
Old 09-10-2003, 10:40 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
When removing the head, do you have to deal with the lifters?
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 09-10-2003, 10:50 PM
Yep, they're part of the camshaft housing which has to be removed to access the nuts that hold the head on.
Old 09-10-2003, 10:54 PM
MrPants's Avatar
where in dfw you at?
84 944 Non Alcoholic
Old 09-11-2003, 12:40 AM
hardflex's Avatar
Thanks for the tips! Are the lifters any special problem?
There only a few weeks running time on the motor after another belt break. The job was done on the cheap, I'm thinking a tensioner was also bad that wasn't replaced, or improper tension on the belt.
MrPants, I'll be working on the car in Midlothian. You wouldn't happen to have a tension tool, would you?
Old 09-11-2003, 05:03 AM
afx afx is offline
afx's Avatar
Send a message via ICQ to afx
The biggest trouble I had was removing the rusted bolts on the exhaust. A tip to make it go faster and easier is to not unbolt the headers from the head while it is in the car. You can take out the head with the headers still attached. It is a real pain to try and fit a wrench in there and take them off while its still in the car.
85.5 Red 944
Http://members.rennlist.com/afx
Old 09-11-2003, 06:21 AM
TCMdocs944's Avatar
Header to rest of system bolts are a bi#%h. The whole process would have taken about 2 hours (first timer) or less if it weren't for one frozen header bolt (2 days).
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 09-11-2003, 12:04 PM
MrPants's Avatar
no unfortunaltely no tension tool here. they are pretty rare to come by, if you found someone in the area that had one id like to know who has one
Old 09-11-2003, 06:16 PM
hardflex's Avatar
I'm in the process now. after getting the covers off, the eccentric tension pulley on the timing belt is ascew and loose, like the stud broke. Is that common? Getting the broken part out looks like fun. The belt is not broken, just no tension, and it's chewed some.
Old 09-12-2003, 10:20 AM
TCMdocs944's Avatar
Some people say the bolt isn't a problem but "clarks garage" begs to differ. I am beginning to believe it myself after your problem.
I wonder if it fails due to overtension? Do you know what your belts were tensioned at?
Old 09-12-2003, 10:51 AM
hardflex's Avatar
I'm not sure what the tension was. It was done by a foreign car mechanic but not a Porsche specialist.
Here's a pic of what it looks like.
Old 09-12-2003, 11:27 AM
hardflex's Avatar
and the crux of the problem
Old 09-12-2003, 01:40 PM
SoCal Driver's Avatar
Wow!
Was the tensioner replaced the same time as the belt?
What's all that coolent? Can you wiggle the water pump shaft?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-12-2003, 04:51 PM
Mike B's Avatar
It's recommended to replace the followers (lifters) in the same place you removed them from. Also, it's a good idea to submerge them in oil after you remove them.
'86 951
'88 928S4 - the project
Old 09-12-2003, 05:05 PM
hardflex's Avatar
I can't say for sure about the tensioner, but it turns smooth as silk, so i don't think it locked up and caused this. I appears from first look the previous belt replacement was a careful job.
The coolant was just spill from disconnecting hoses, I think. It's possible the car was run previous to the belt repair with a bad water pump, as my brother is kinda a cheapskate and the cost of the pump put him off. That might be some of the rusty stuff you see.
It bent all the valves. I'm worried about removing the broken threads from the block. I'm afraid I'll have to pull the motor to get it out.
nothings ever easy anymore ;-(
Old 09-12-2003, 05:17 PM
