scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Question a/c low end
could someone tell me where the low end of the a/c is?
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 09-12-2003, 10:01 AM
Scott R's Avatar
If you mean the low side, or "vapor" line, its the line that goes most directly from the compressor to the condensor. In the case if the 944 the low side service port is on the compressor itself.
The high side (liquid line) line will return from the condensor to the dryer and into the evap core.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-12-2003, 03:57 PM
well i was tring to find it so i could tell if it had been swiched over or not, and it has... the service port was right against the firewall near the center of the engine bay.
Old 09-12-2003, 05:12 PM
