Let's go shooting.
Dark Skies's Avatar
Idling problem fixed now my headlights won't pop up
If you're having the same bizarre problem then try looking at the relay connections on the popup motor under the bonnet (hood). I found that slightly touching the relay operated the motor. When I was suffering poor idling the rough vibration was jiggling the connections sufficiently to cause the lights to operate and thus masked the problem. Once you've sorted any poor idling problems the headlight bug can reveal itself. I stripped the headlight motor down and pinched the female connections sufficiently to tighten them. Sorted! Thought it might be worth passing on.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 09-25-2003, 04:36 AM
Had the same problem but sorted it out the lazier way by bending the male pins on the relay slightly inward. Problem got worse when it rained and has started again so need to do it again.
Old 09-25-2003, 07:30 AM
SoCal Driver's Avatar
Should be a rubber cover over the relay.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-25-2003, 10:30 AM
TSNAPCRACKLEPOP's Avatar
i knew a gal whose didn't , then she had some kind of surgery, they pop up just fine now. touching helps them operate, she can bend those male pins, and no rubber covers required!
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 09-26-2003, 11:17 AM
Must be Friday.
Old 09-26-2003, 02:13 PM
