lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
Question on front spring spacers
I'm installing new Weltmiester proportional springs in a set 944 turbo strut towers. They are much shorter than the stock springs. Do I need the spring spacers that I see listed in Windward and Perf Prods to make the car sits at the right height? I really didn't want to lower it much from stock (maybe an inch or so). Thanks
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 09-27-2003, 08:12 AM
If the springs are meant to lower the car, why would you need spacers?
Lowering springs are usually have a stiffer rate, so the difference in the free-length of the old and new ones is irrelevant. Of course, you could always read the instructions.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-27-2003, 12:54 PM
lousailor's Avatar
Ah Ha, Instructions! Well unfortunately the spring were an Ebay purchase so I count myself lucky they fit at all, but alas no instructions. Fortunately I think it should all work out. Once I finish painting the rest of the strut mounts I'll put them all together and measure it next to the originals. Thanks
Louie
'76 924 - Long Gone
- Mario Andretti
Old 09-27-2003, 02:48 PM
TNT25169's Avatar
Send a message via AIM to TNT25169
Well, I put the 220 lb H&R springs (the mag says weltmeister) from Perf. Prods onto the front of my car and when I was ordering these, the guy on the phone told me that you should order the spacers if you want your car to sit stock height. He also told me that my springs weren't going ot lower my car which was a lie. I don't mind, it only dropped like 3/4 of and inch but I would suggest getting the spacers. Just my 2 cents....
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 09-27-2003, 10:55 PM
