Option code 456
Just purchased an '86 coupe and was wondering if someone could describe what's meant by 'Sport Shocks and stabilizer' as referrenced by the option code 456?
thanks.
Old 09-29-2003, 02:25 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
koni yellow shock and sway bars all around, that is awesome i have had them on both of my cars and they are just amazing, so much nicer than the original boge shocks, you don't know how lucky you are to have that. Great for autox!, good work on geting a 944 thats awesome
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 09-29-2003, 07:25 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Aren't they adjustable shocks?
I have this option as well, but my fronts are coil overs (obviously not stock), the rears are koni yellows, but a little soft in really hairy stuff, can't I unbolt them, and tighten them up?
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 09-29-2003, 08:40 PM
Z-man's Avatar
Koni Yellows / Sport Suspension is option code 474.
Not sure what 456 is: the sources I have do not have that listed.
Do you have yellow colored shocks on your car?
-Zoltan.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 09-30-2003, 06:37 AM
ilikemy944's Avatar
err, your right, I have 474, dunno 456 :P
Brad Tompkins
Old 09-30-2003, 09:25 AM
http://www.cantonia.com/option_codes.html
http://www.geocities.com/MotorCity/3322/spec.htm
Both of these list the Option code 456 as Sport Shock Absorbers and Stabilizers and Option code 474 as only Sport Shock Absorbers.
I guess the only way to be sure is to get a wheel off and get in there for a proper look?
Old 09-30-2003, 10:07 AM
SidVicious's Avatar
Brad, maybe you'll find your answer here: http://64.226.197.185/Paragon/Info/koni_adjustment_procedures.htm
Old 09-30-2003, 10:44 AM
