Transmission problems
Hi, I have another question.
Sometimes the car has trouble shifting into 2nd gear. The syncronizer is going out I think. Is there a way to get this fixed? It is also sometimes hard to shift into reverse. What can i do about this?
86' Porsche 944 N/a |
Custom User Title
Well, new tranny fluid never hurts anything. Won't fix a real problem, but can smooth it out a bit. Also provides an opportunity to do a rudimentary inspection by checking the drain plug for metal shavings. But inevitably it will eventually need a rebuild. How many miles are on it?
73580 Miles exactly. Where does one put the tranny fluid? Its a manual
Cant imagine wearing the syncros at 73k, but anything is possible. Check the linkage, and repalce the tranny fluid. There are two large 17 mm allen head sockets on the drivers side of my 81 924. Remove the filler plug first (top) the remove the drain plug (bottom). Refill with a qualitity tranny fluid, I use Swepco but there are a few other good ones out there also.
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
Swepco or Mobil 1 synthetic work well
Some silvery dust in the fluid is normal - don't want to see are chunks of metal. At 73K miles, the only cause I can think of is abuse. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
i dont think theyve changed the tranny fluid in like 4 years. would this fix the problem? or could something be damaged.
what weight oil is recommended??? i am not exactly easy on my car and am in a warm climate. i am moveinbg to texas in the next couple of weeks and am planning on changeing it first. i allways use either redline or mobile 1 when i am short on$$$
84 944 5spd,85.5 auto Last edited by guinnastysassy; 10-12-2003 at 07:52 PM.. |
Ok, how do i drain and replace the tranny fluid on a manual? I looked in the porsche 944 owners manual books and it didnt say crap.
