Turn Signals
My turn signal indicator on the instrument panels stay solid, when I switch them on, and nothing happens at the lights them selves. I have read other threads about the relay being the most likely fault. Would this be true, if the turn signal fuse blows as well?
If I am reading you correctly, when you use the turn signal, you get a solid light rather than a flash.
That would be a relay failure. If a fuse is blowing regularly, you have an electrical gfault somewhere in the circuit. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
