pulling engine block out
86 944 engine.
I have the head off, and I need to pull the block out to remove a broken timing stud. The front half looks easy enough, but I've never been into the torque tube setup. Is that just splined so it will slide right out after I unbolt the bell housing? Any recommendations out there for this procedure? You guys helped alot on the head removal. Thanks for the help!
72 914 2056: 74 9146 2.2: 76 914 2.0 |
You can work thorugh that starter access hole and remove the clutch to flywheel bolts then seperate the bell housing from the block and lift it out.
If you search the archives there was a thread a while back on which was easier, pulling from the top, or dropping out the bottom. The thread goes into great detail on how to pull the motor from the top.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Thread Tools | |
Rate This Thread | |
