Transmisson
Hey. I was Driving my little N/a today, and something was wrong.
It was hard to shift into second like I have mentioned before on the forum, but when i was going down a road, trying to shift from 2nd to 1st, the whole transmission just seemed to freeze up. I was in neutral, just rolling, and i couldnt shift into any of the gears. Eventually i got it into first, but could this problem be that the transmission oil hasnt been changed in a while? Or is it a bigger problem?
Also, if anybody can tell me where i drain the transmisson oil, and fill it back up, that would help. because I, uh looked for like 2 hours, and i couldnt find anything. Then i went to autozone and their cheap asses still didnt have the Haynes manual. Oh well, any help is greatly appreciated, thanks.
86' Porsche 944 N/a
Old 10-18-2003, 07:19 PM
AFJuvat's Avatar
The drain plugs are on the drivers side of the transmission - you need a 17mm allen wrench (or hex socket) to remove them. remove the upper one first, then the lower.
It is very possible this is a fluid issue. Otherwise, it sounds like a synchro ring\hub on its way south.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-18-2003, 07:24 PM
Danke! Danke!
86' Porsche 944 N/a
Old 10-18-2003, 07:37 PM
Oh yeah, how much fluid do i add to this thing? Should i just poor as much as i can?
86' Porsche 944 N/a
Old 10-18-2003, 07:43 PM
AFJuvat's Avatar
Fill it up until the fluid level is just under the bottom of the upper drain plug.
About 2.5 quarts
Bitte.
AFJuvat
Old 10-18-2003, 07:49 PM
I looked under there i didnt see any 17 mm hex guys. I guess i have to look harder, but my friend said that was a bad idea because we have to pump all the air out of the transmission or something? He said we shouldnt do it because we dont know how much to pump the transmisson or something. Is this true?
86' Porsche 944 N/a
Old 10-19-2003, 02:01 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
balderdash!
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 10-19-2003, 02:12 PM
SoCal Driver's Avatar
Bolder Dash? A new Oylimpic event.
The plugs are in the side of the transmission on the drivers side of the car just forward of the axle.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-19-2003, 03:19 PM
Ok, NOW another guy said not to do it because there could be metal chunks stuck on the gears and it could blow the whole transmission, is this true? Should i still do it by myself?
86' Porsche 944 N/a
Old 10-19-2003, 03:36 PM
Gesh! Do you believe everything you are told?
You do need either a 17 mm Allen wrench or special socket. These plugs are notorious for NOT wanting to come out. They have tapered threads like hard pipe fittings and mech's tend to over tighten them.
Old 10-19-2003, 03:48 PM
Roger Hall's Avatar
I have heard people say that if you have not changed your tranny fluid in a long time you are better off not changing it at all. I have mostly hear this about auto tranny's. Sounds like crap to me.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 10-19-2003, 05:30 PM
todwic's Avatar
I'll second the Crap. My step dad owned a transmission shop. Change your fluid as often as you want/need.
'86 951
Old 10-19-2003, 10:51 PM
todwic's Avatar
Just clean the plug/drain area. I promise you'll have more problems if you let the outside in than letting the inside out.
'86 951
Old 10-19-2003, 10:52 PM
vott does ziss do?
ronin's Avatar
of course if it comes from us...
truuust us, truuuust us
Old 10-20-2003, 12:10 AM
MrPants's Avatar
if you are real worried just take it to a shop. i personally dont let any of the cheapo trnny shop type places touch my car. i really dont think you have anything to worry about changing the oil.
my reverse gear is stubborn sometimes. if you let out the clutch in neutral for a second and then try shifting it should go in. i have the same problem in reverse
84 944 Non Alcoholic
Old 10-20-2003, 12:33 AM
Non Compos Mentis
Is your linkage sloppy?
Old 10-20-2003, 08:57 AM
Old 10-20-2003, 10:37 AM
vott does ziss do?
ronin's Avatar
loook into my eeeeeyes
Old 10-20-2003, 11:24 AM
dzachry's Avatar
Send a message via AIM to dzachry
Well Rock is it fixed???
Rock if,you need A tranny I Have a tranny that gose into an 84 NA
David Zachry
84 944
Old 10-20-2003, 04:52 PM
i dont think i need a new tranny, my stepdad said it was doing the exact same thing at 49000 miles. I think there is a smaller problem, but what is the linkage and how would i check that lol. You guys probally want to beat me by now, but im a kid dammit! im still learning!
86' Porsche 944 N/a
Old 10-20-2003, 05:59 PM
