1st to 2nd is screwy, and reverse is really weird...
often times when i go from 1st to 2nd it feels rather "rough" going into gear, then 2nd to 3rd isn't as bad but still feels not like i think it should feel like. kind of like gears grinding a little.
ALSO, sometimes when i try to go to reverse, i push in the clutch and can pull as hard as i want (but i don't) and it won't go into gear, i can push it back to neutral and try again, but it still won't work. eventually what i do, is put it as far as i can in reverse, let out the clutch a little (it will grind a slight bit as i also push the gear back into neutral) then i can finally pull it into reverse. ^^^why does it do this? is my transmission going?
'82 928S ![]() '85.0 944 Not Awesome - Being Parted Out
beats me! but this is similar to what is happening to me.
86' Porsche 944 N/a |
when you push the shift lever back into neutral let out the clutch for a second and try it again. some times the gears line up tooth to tooth so they cant get in. i think it means bad synchros.
84 944 Non Alcoholic |
Thought you destroyed third gear? Now you are working on first and second?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Does rough 1st to 2nd co-incide with cold mornings and a cold engine / gearbox? Is it fine when all warmed up?
If so changing gear oil to something thinner might help (ie synthetic) mark
1991 944 S2 (no more, sold it, gone to a good home) 2003 Infiniti G35 Coupe, 280hp, Black |
the gears do that stuff warm or cold, and the weird thing is, it doesn't ALWAYS happen.
