first start low idle
whenever i first start up my car, the idles bounces back and forth from about 500 - 800 RPM. It feels like it will almost die...then jump up. But about a minute later, it will idle at about 1000 RPM just perfect. Any ideas? Thanks!
1986 944 non-turbo |
how cold is it where you live?
1984 944 N/A 1996 Golf Gl Drive fast. Take chances. If you can't dazzle them with brilliance, baffle them with bull. - W. C. Fields |
i'm in south georgia. Its 75 degrees here in November!! LOL
Well then I don't know. My car does that in the morning but after it has been like 30 degrees overnight.
Air Flow Sensor. The double contact wiper on the resistor board has worn away the carbon. You can lower the wiper assembly and move the contacts to a "fresh" area of the resistor carbon.
See http://www.frwilk.com/944dme/afm.htm
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
i just got the car back from the porsche shop...the reason the the car wasn't even running right was because of the air flow meter! so they replaced it with a good but used one. Is the air flow sensor inside the air flow meter box? do you still think it may be that?
how do i get the black cap off of the air flow meter?? does it just pop off?
