what is wrong
I have an 83 844
it sometimes has trouble starting feels like it is not getting gas. If I let it sit for 5 or 10 min it will start fine. This has been happening more frequently lately. could it be a fule pump if so what is nessessary to replace it? |
When was the last time you replaced your fuel filter?
Could also be the reference and speed sensors. Been a rash of these lately breaking their wires inside the connectors or the plastic heads. Please put your car and year in your signiture line.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
DME relay... stops flow of fuel when it dies... intermittently
Brad Tompkins Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968 |
so perhaps a dme relay or fuel filter. Are either of these things something that i could fix myself I have no mechinacal experience beyond changing my oil and fooling around with two cycles
83 944na |
All you need is a jack, jack stand, and wrenches (17mm and 19mm?) to change your fuel filter. All you need to change your dme relay is nimble fingers and your owners manual.
The crashes people remember, but drivers remember the near misses. – Mario Andretti 1991 944S2 Rally #951 Rally-America.com |
how much would they cost which should i do first?
83 944na |
Do the DME relay first..... check the date stamped on it. If its older than 5 years more than likely you will need to replace.
The fuel filter can be a PITA to replace unless you enjoy getting covered in gas. Now you mention 5-10 minutes you wait and then it starts............is this on cold starts or hot starts???
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
cold starts
83 944na |
but on warm days i have not driven the car since summer but I am trying to get this thing fixed during the winter so I can enjoy her during the summer
83 944na |
so you guys are pretty sure that it is not the actual fule pump itself
that is good news
83 944na |
Did you?
