Ehab's Avatar
Post Removing Front Fender - Help.
Hey guys, after replacing my brake pads the other day, I forgot to pump the pedal before moving the car, and so I ended up denting the front tip of my driver's side fender.
Should I remove the whole panel to try to hammer it out, or is it too hard? Otherwise I will have to pull the dent out.
Thanks.
E
1984 944
Old 07-16-2001, 02:34 PM
Banned
Post
If the paints not cracked or broken, try taking your car to one of the new "Paintless" dent removal services. These guys, if you have them in your area, work wonders. I saw them pull three good door dings from a early z-car with no paintwork needed. The key to success for them is that the paint film must be intack.
Old 07-16-2001, 02:39 PM
Ehab's Avatar
Post
I think that the paint is scratched a bit, I can see the primer under.
The other thing is that I just found out I have to cut my nose panel loose, since mine is NOT removable, so I have to take it out too to fix a dent, paint, then install a new head crest.
E
Old 07-16-2001, 09:07 PM
Leigh 13's Avatar
Post
http://www.pelicanparts.com/ultimate/Forum5/HTML/003364.html
Old 07-17-2001, 06:23 AM
