Lightbulb turbo internals in a n/a ?
When rebuilding an earlier n/a engine, has anyone ever thought of slightly shaving the top of the block to increase compression. I would think that turbo pistons, rings, bearings, and crank could be fitted with some machining of the block. As far as I understand it, there is more stress in a turbo engine. The only thing would be that a higher rated octane gasoline would have to be used to retard knock. Any thoughts ?
Old 07-18-2001, 03:45 PM
Petie3rd
Mrmerlin's Avatar
Post
[QUOTE]Originally posted by Cake944:
Hi cake, the best wat to make HP is with cubic inches a turbo piston assy has less compression than a NA does, so the hot setup is to increase cubic inches, IE get a 968 engine, and install it into your NA.or rebore and install bigger pistons.....Stan
Old 07-18-2001, 04:06 PM
Post
I have no plans on attempting somethinh like this, but the thought crossed my mind the other day. That was kind of what I was thinking. There is no substitute for cubic inched. I do not know the relationship in bore and stroke dimensions between a n/a and a turbo. I would think that a turbo would have higher internal stress from the forced induction. The higher compression should exert more force on the piston upon detnation since the fuel is starting in a "smaller" area. The gas wants to expand rapidly, therefore I tend to think that there is a greater force to create the momentum. Any other ideas ?
Old 07-18-2001, 04:33 PM
Send a message via ICQ to porscheboi928s/c944t/n
Post
DEstroking...
Old 07-18-2001, 05:02 PM
Post
Jusr get longer rods with a new crank.
Old 07-18-2001, 06:02 PM
Post
Sorry about the double post.
[This message has been edited by Cake944 (edited 07-18-2001).]
Post
The turbo crank, pistons and rods would only give you lower compression and less power in the na 944. The turbo pistons are forged and would be a bit stronger than the cast na 944 pistons but the cast ones are plenty strong.
A turbo needs less static compression so the turbo can fill the chambers. Don't even think about putting turbo insides in your na 944 engine. It will gain you nothing. Put headers/free flow exhaust, chip, high flow air cleaner and stuff like that on you na 944 for more power.
Old 07-19-2001, 07:02 PM
Petie3rd
Mrmerlin's Avatar
Post
[QUOTE]Originally posted by T86951:
Thanks T86 951, That is what I was thinking.....Stan
Old 07-20-2001, 08:55 AM
Brandon85-944's Avatar
Send a message via ICQ to Brandon85-944 Send a message via AIM to Brandon85-944
Post
hey cake944....can i get your email address to request the order information that you said you had for the male end piece on the O2 sensor wire that runs to the DME...i tried that link that you posted and it got me no where...
thx..
Brandon85-944
Old 07-22-2001, 01:24 PM
geoffbaltz's Avatar
Post
Wouldn't the best option for a NA be a 2.7 Litre stroker kit? I have heard about these but never seen one. I think there are stroker kits for both the NA and the Turbos. Does anyone know more? Man, I would love more cc's in my turbo. Now that would be killer.
Old 07-22-2001, 04:53 PM
