wolfrpi's Avatar
Question Compression test results
Anybody hear ever compression test their cars?
Just curious as to the results for both turbos and NAs. Mileage would also be helpful. I was suprised to learn that my 213k 951 had 145-150 across all four cylinders, even after I have run it at 18-20 psi for 2-3k miles. Are all these motors really this strong?
Erick
http://www.pelicanparts.com/cgi-bin/pmpre/pm.cgi?action=display&login=aka_951
Old 07-22-2001, 02:31 PM
Petie3rd
Mrmerlin's Avatar
Post
[QUOTE]Originally posted by wolfrpi:
Hi Wolf , mine has about 98,000 and shows 145 to 150 it runs strong......Stan
Old 07-22-2001, 04:06 PM
Thumbs up
That sounds about right. When I put my ape maf and k27 turbo I had about the same readings and that was when the car had about 60K on the motor(currently had 97K). You should do a leak down test. If you run between 4-6% in each of the cylinders, the motor is still in excellent condition. Ken
Old 07-22-2001, 04:45 PM
MAS MAS is offline
Post
Yes, they are this strong. My 87 924S (same engine as an 87 944) recently tested at:
1.70/1.75/1.70/1.75
when a Porsche mechanic checked it out.
It has about 100,000 miles on the car (and original engine).
-MAS
[This message has been edited by MAS (edited 07-23-2001).]
Old 07-23-2001, 03:40 AM
Light,Nimble,Uncivilized
Post
PPI results for my '86 944 with 121K:
165-170 across the board.
1986 944 NA
Old 07-23-2001, 05:54 AM
