Is Top Dead Center referenced by the DME from the leading edge or trailing edge of the signal from the flywheel reference sensor & set screw?
drew1
drew1 wife has 924 turbo |
bump
Good question. I would venture that the peak threshold voltage would trigger the circuit. So this would depend on how close the inductance sensor is to the pin and how fast the pin is traveling.
Don't think this is as critical as you may think it is as long as the circuit fires. From the DME testing plan I would guess that 2.0 volts is the trigger. Then it just may be the clean spike.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Thank you for your replies.
drew1
Let's go shooting.
My wife happened to be walking past the screen as I was viewing this. She says:
"Oh it all happens so goddam fast I doubt the lil' box notices anyhow"' Ya gotta love the logic.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." |
