I'm installing a CR-1 radio in my 93 RSA and am having a problem with the security code. This is the same radio installed on many 924/944. I assumed the code would be some combination of 1-6 corresponding to the radio preset buttons, but the code the dealer gave me is 3083. They said you push the first button 3 times, the second button zero (or 10?) times, the third button 8 times and the fourth button 3 times. I can't seem to get this to work and the manual is not very clear.
Can someone confirm this is the proper way to enter the security code? Also, I have the radio hanging out of the dash until I know it will work. There is a micro-switch on the top of the unit. Does this need to be depressed to allow the code to be entered? Thanks
Scott 61 356 S90 GT 93 RSA 01 M3 |
Will work for parts
This radio was installed in 968's and early 90's 911's. I dont know why the method described diddnt work. Thats how i thought coded Blaupunkts worked. Try the microswitch.
'88 944 240,100 miles -race car '05 Boxster 110,000 - Daily Driver '74 911 Targa - long term project |
