Post engine removal I AM stuck.. Help
Pulling the engine on my 951 Engine will come out of Bel Housing by about 1" and the it feels like something is holding it on the right lower side...Am I missing something Ihas trying to pull it with the crossover pipe, turbo and downpipe on. I have unbolted the two halves of the downpipe. I am getting angry...much more of this and I will part her out..LOL
Old 08-03-2001, 08:30 PM
951carter's Avatar
Post
sounds like you left the sensors in. they have to come out.
Old 08-03-2001, 08:34 PM
Post
crank sensor are out
Old 08-03-2001, 08:42 PM
951carter's Avatar
Post
the shifter fork.
Old 08-04-2001, 05:22 PM
Post
hi. you will have to look up the turbo side of the engine on the bellhousing, for a small bolt to take out, then just below the bolt is a hole with thread's in . with the bolt out, put a long bolt into the thread's and pull the shaft out of the bellhousing, to release the clutch release fork. then pull the engine/ bellhousing apart.
good look mike.
Old 08-05-2001, 01:20 PM
