Headlight Problem
Ok guys Rock is having another problem. Here it is.
I was driving home and both of my headlights were out. I went up and smacked them a few times and they both went on. Then the drivers side one went off. So i had to drive home with my brights on. When i got home and turned my brights off, both of the lights were off. So i smacked them again and they turned on. Is the bulb dying, or is some wiring going bad or something?
86' Porsche 944 N/a
Old 12-03-2003, 04:43 PM
tomeiche's Avatar
try bulb grease on contact ends
944 guards red 82- slotted rear turbo spoiler- new dash cover- red dials - k@n dropin filter- throttle cam upgrade- astrali wood steering wheel {can now see temp guage}-(www.astrali.co.uk)blue/white fogs {RING}-reversing sensors-alpine cd-roil gold engine protection
Old 12-03-2003, 06:53 PM
SoCal Driver's Avatar
Bulb grease???
Babblefish couldn't translate that one.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-03-2003, 07:48 PM
flangermog's Avatar
Try cleaning the contacts where the bulb joins the socket attached to the car. Next apply some grease to the contact blades on the bulb, this should prevent rusting of the metal contacts.
At the same time you can inspect the wires to see if they are brittle - if so replace
People from the Wirral generally talk back to front
tr: try grease on bulb contact ends
Babelfish Schmabelfish
(x)'89 944 S2 Cabriolet (Guards Orange) :
( )'90 944 S2 (Maraschino Dead!) :
( )'89 Audi 90 Quattro 2.3 20V :
( )'92 Renault Clio 1.4 :
Old 12-04-2003, 05:12 AM
Ornery Bastard
Originally posted by SoCal Driver
Bulb grease???
Dielectric grease.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 12-04-2003, 07:58 AM
944 Speed Grrl's Avatar
Send a message via AIM to 944 Speed Grrl Send a message via Yahoo to 944 Speed Grrl
Your relay may also be going bad.
Samm--It's short for Samantha...
Keystone Heights, Florida
Florida Crown Region--PCA
2006 Acura RSX
1984 944 Track Car
1972 914/6 Race Car
Old 12-04-2003, 08:43 AM
Ornery Bastard
Isn't the headlight relay in the relay board inside the car though? If so, smacking the headlights themselves wouldn't jar the relay and make it work again. AFAIK, the only relay that would be jarred or jiggled by smacking the headlights is the headlight motor relay.
I've been wrong often before though.
Aaron
Old 12-04-2003, 08:50 AM
The current for the head lights does not go through the relay on the headlight motor.
There is a relay in the fuse box for the low/high beams that is opperated by the latching switch inside the steering column lever assembly.
Since you are hitting the front of the car and not the steering column or the fuse/relay box I would check the grounds to the chassis behind each headlight and all of the flexing wires from the chassis to the headlights including the plugs on the headlights.
Old 12-04-2003, 09:16 AM
TCMdocs944's Avatar
I second for grounds or loose wire...
the "smack-it" test is usually good for that.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 12-04-2003, 09:24 AM
There is the relay for the light motor. I had the same problem with my old car.
2006 Acura RSX
1984 944 Track Car
1972 914/6 Race Car
Old 12-04-2003, 02:20 PM
MrPants's Avatar
yea there is another relay on the side of the headlight motor. there is also a 3 wire connector that you might want to check for corrosion.
84 944 Non Alcoholic
Old 12-04-2003, 02:35 PM
Ornery Bastard
That relay only controls the motor. It has absolutely nothing to do with whether the lights turn on or not. If that relay fails, the lights still turn on, they just don't get rotated into a useful position.
Aaron
Old 12-05-2003, 09:18 AM
