fast924S's Avatar
Send a message via AIM to fast924S
Angry Heater control jammed
Hey I was just inside my 1987 Porsche 924S doing a little work and I noticed my temp controle is jammed all the way to hot and It wont move back. Its amost like the control is bent. anyone evr have this problem???
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 01-06-2004, 01:45 PM
SoCal Driver's Avatar
The cable sheath is pulled loose from the bracket behind the console or something has jammed the lever on the valve (located between the back of the engine and the firewall).
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-06-2004, 05:13 PM
fast924S's Avatar
How hard is it to get behine the dash to the cable??
Old 01-07-2004, 01:20 PM
The bezel that the three sliders and the blower speed control knob stick out of has two philips heads in the bottom. Takes a stubby screw driver. Pull the sliders out and the knob out. The bezel will then come off.
Depending on what radio you have it may be in the way of the two screws.
Use a flash light to follow the levers to where the associated cable sheath is clamped to the plastic frame. The common failure is to have the metal retaining clip break off. That is the plastic part of the frame the clip latches to breaks off.
Think there are three screws to remove the bracket. Two in the front and one toward the "back" of the bracket.
Old 01-07-2004, 01:44 PM
