Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
hit a roadblock changing rotors...help!
me and mikect are attempting to install my cross-drilled rotors on the front of my car. we got the pads out, the calipers off, and undid the 5 bolts holding on the wheel spacer. even after removing the bolts from the rear of the rotor, the wheel spacer still won't budge.
now, i am attempting to do this without having to remove the hub, ie no repacking bearings. so what am i missing? do i need to remove the dustcap and get off that allen bolt as well? i was under the impression that i wouldn't need to do this.
any help would be most appreciated.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 01-08-2004, 03:34 PM
Writer/Teacher
CJFusco's Avatar
oh,and if so, how the hell do i get that dut cap off?????
Old 01-08-2004, 03:39 PM
SoCal Driver's Avatar
In a bit of a bind?
What five bolts are you talking about?
Not the wheel studs????
They stay in.
The aluminum spacer just slides off of the wheel studs. Mine don't have any fasteners holding them to the hub/rotor. Might have to tap them around the edge to get them to slide off.
Now the rotors have one or two flat head screws holding them to the hubs.
Be sure to put the new rotors on where you can reuse the flat head screw.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-08-2004, 04:03 PM
AFJuvat's Avatar
Check your PM if you get stuck.
Ok, To get eh grease cap off, take a hammer and chisel to the groove in the cap. - it will work itself off.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-08-2004, 05:10 PM
AFJuvat
Once you get the aluminum spacer off.
I use a nail crow bar. About 10 to 12 inches long.
Old 01-08-2004, 10:35 PM
Oh. The speedometer cable comes though the grease cap on your left hub . Has a clip on it. May be covered by a gob of putty. You have to disconnect it and push it back into the hub to get the grease cap off.
Old 01-08-2004, 10:37 PM
Writer/Teacher
CJFusco's Avatar
see my new post, please !!!
Old 01-08-2004, 10:48 PM
