Post 2.7L engine
Are the 2.5 and 2.7 litre 944NA engines different externally?would you be able to tell one from the other just by looking at it?
Old 09-04-2001, 12:18 PM
Bob's944's Avatar
Send a message via AIM to Bob's944
same bore, longer stroke... I'm guessing that the 2 engines appear identical... but i really don't know
Old 09-04-2001, 12:22 PM
Scott R's Avatar
Post
Yes they are visually different, look at the valve cover, the plug wires are rescessed into the cover itself. Also the instake has a more "turbo type" look to it.
Old 09-04-2001, 12:43 PM
mideastmafia's Avatar
Send a message via AIM to mideastmafia
Post
isnt that the "S" your talking about scott? the 2.7's looked like the other engines and were only available in 1989
SHAUN
[This message has been edited by mideastmafia (edited 09-04-2001).]
Old 09-04-2001, 01:55 PM
wolfrpi's Avatar
Post
weren't they bored? I thought that the stroker crank would bring displacement to 2.8?
Erick
86 951
http://www.pelicanparts.com/cgi-bin/pmpre/pm.cgi?action=display&login=aka_951
Old 09-04-2001, 03:07 PM
Bob's944's Avatar
http://www.pelicanparts.com/944/tech_specs/944_model.htm
Old 09-04-2001, 03:18 PM
Bob's944's Avatar
944, 944S, 951 all have the same bore and stroke, '89 944's have the same bore, but use the longer stroke crank from the S2, the 944S2 has a bigger bore and same stroke as the '89 944... best of both worlds... 968 is the same as the S2, but adds variable valve timing.
Old 09-04-2001, 03:23 PM
wolfrpi's Avatar
Post
Take another look Bob
Erick
86 951
Old 09-04-2001, 03:40 PM
wolfrpi's Avatar
Post
Hope you don't have a 2.7 that you're currently rebuilding...lol
Erick
86 951
Old 09-04-2001, 03:41 PM
Bob's944's Avatar
yup, i got it backwards, they all have the same stroke and bore (who the hell lists it like that?? i always have seen bore THEN stroke #s), '89 were same crank and fatter bore, S2 are the only ones with the longer stroke crank, same bore as the '89s... still best of both worlds
Old 09-04-2001, 03:48 PM
Post
so they are exactly the same cept for the little numbers under the manifold?
Old 09-04-2001, 06:28 PM
