No substitute!
Power Steering Rack Seal
Searched this forum and did not find a specific answer so am posting these questions.
1. I have seen exploded parts diagrams for the 944 power steering rack, but with no part number details. Can I find these drawings/catalogs anywhere? 2. Is it possible to buy only a single seal for the rack instead of the whole rebuild kit? For example just the top collar is leaking. How to find part number for that seal and where to source it. If I could just do that one seal (instead of the whole kit) and stay on the road for the summer instead of taking the car down and replacing/rebuilding the rack, I would love it. Thanks in advance!
1984 944 NA Man Grey (Sold) 1985 944 NA Man Guards Red 1985.5 944 NA Auto Kalahari Beige |
The parts catalog is on the <Porsche website> and power steering section is on page 163 (see below). Porsche do not sell the reseal kits so those are made up by the aftermarket and afaik individual seals are not available. However if one seal is bad it is likely that others are too, so it’s bad practice to simply replace one. Maybe you can use some internal or external sealant to patch things up until you can do a full reseal, I’ve done that with the rear balance shaft seal before.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
No substitute!
Thank you for the reply!
I have a spare rack that I have just reworked with the kit from Pelican. I can swap it out later and rebuild the one I remove. I know that replacing the one seal is probably not the "correct" version of the answer, but, if it bought me the summer without leaking, I am fine with that and can swap racks in the winter. Alaska summer is precious, and a 944 out of commission is just plain bad. I have that catalog breakdown. Looking for the breakdown of the rack.
Quick Seal Fix
Apply a couple of drops of brake fluid onto the seal. If the seal is still intact, the brake fluid will make it swell, possibly sealing the leak for a time.
Peter
1968 912 SW Targa (Restoration: almost Tangerine again) 1986 951 2013 Cayenne Diesel Last edited by Peter Graham; 05-30-2019 at 06:30 PM.. |
