Macfreak007's Avatar
Send a message via AIM to Macfreak007
replacing front struts
my front driver side strut was bent so the shop i took it to put a crappy used one the car, the passenger strut is in good condition so the questiuon is should i try to find a used one of should i just order new koni's from paragon?
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 02-16-2004, 04:22 PM
CSU944's Avatar
Bent cartridge or housing?
Old 02-16-2004, 10:23 PM
..P ..P is offline
put them on in pairs two fronts, two rears, of the same manufacturer.
I recently installed new OEM Boge gas units on my '84, it wasn't too bad of a job, and the rears were a walk in the park. The fronts took some time and I actually had a buddy give me some help too.
P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 02-17-2004, 07:02 AM
SoCal Driver's Avatar
Should always match the inserts when replacing one of the struts. If both had considerable mileage then replace both of them.
I had a strut that was bent so bad I could not get the insert out.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-17-2004, 07:08 AM
Composite Shop Owner, DJ
MixMasterK's Avatar
Send a message via MSN to MixMasterK Send a message via Yahoo to MixMasterK
Make sure you go in for an alignment after working on any part of the suspension including the front struts.
'86 944, 5 Speed (Daily Driver)
Old 02-17-2004, 11:59 AM
fast924S's Avatar
Send a message via AIM to fast924S
I love doing alignments They pay 2hrs, an it only takes about 45 mins - 1hr
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 02-17-2004, 04:43 PM
repoman's Avatar
just put in pwr steering rack and got new strut inserts for $30 each.
my trusted shop quoted me $200 on labor which sounds about right
'84 944 auto stock
Old 02-17-2004, 10:55 PM
