replacing front struts
my front driver side strut was bent so the shop i took it to put a crappy used one the car, the passenger strut is in good condition so the questiuon is should i try to find a used one of should i just order new koni's from paragon?
'84 944na -- Sold '84 944na -- Sold '85 944na, -- Sold |
Bent cartridge or housing?
put them on in pairs two fronts, two rears, of the same manufacturer.
I recently installed new OEM Boge gas units on my '84, it wasn't too bad of a job, and the rears were a walk in the park. The fronts took some time and I actually had a buddy give me some help too. P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet My other car is a Chris Craft Commander http://www.chriscraftcommander.com |
Should always match the inserts when replacing one of the struts. If both had considerable mileage then replace both of them.
I had a strut that was bent so bad I could not get the insert out.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Composite Shop Owner, DJ
Make sure you go in for an alignment after working on any part of the suspension including the front struts.
'86 944, 5 Speed (Daily Driver) |
I love doing alignments They pay 2hrs, an it only takes about 45 mins - 1hr
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
just put in pwr steering rack and got new strut inserts for $30 each.
my trusted shop quoted me $200 on labor which sounds about right
'84 944 auto stock |
