RaF944's Avatar
Post Right rear wheel making Knocking noise *HELP*
Ok my right rear whell is making a knocking noise.. like klank klank klank when i accelerate 5mph or over. It sounds sort of how bad CV joints would sound but with a knocking noise. Is it a Wheel Bearing? or what
85.5 Porsche 944
Old 11-04-2001, 07:36 PM
Post
mine did the same thing it is probably a loose wheel. Take the wheel off then put it back on and tighten the nuts evenly.
Old 11-04-2001, 08:08 PM
Cool
Check your CV axles for looseness then your bearings. If neither are evident then repack your CV joints and reverse their re-installation (switch sides from trans to arm)
Good luck!
Brock 86 951
Old 11-04-2001, 09:00 PM
Question
I knew the wheel beerings were bad on the 944 I'm driving. But, I started to here that same knocking a few days ago. Is that a sign of the very end of the bearings??? Planning on bringing it for a 300 mile trip this next weekend and don't want to end up on the side of the road with another tow truck. I've already had my share for this year.
Joshua Harrison
Porsche owner at heart
Old 11-04-2001, 09:08 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Post
wheel bearing man..happened to me twice.i think they are 17 bucks each....ussually inner goes before outer bearing-chris
"Faster,Than,You"
"Wish I had a 951....."
"Ive tried so hard and got so far but in the end it doesnt even matter"
http://hometown.aol.com/fty9999/944land/944land.htm
Old 11-05-2001, 12:12 AM
Post
There's another posibility:
Check the gearbox support to the transversal beam above it. On my car (Cup) the gearbox support got some play, and the gearbox started moving in relation to the beam, creating a "clonk" every time the 'box was streessed, which was often (LSD in the 'box). That unwanted moving was enough to fatigue CRACK the beam in three pieces, which was pulling on the rail chassis...
So if it took 40K miles on my (hard used) car, maybe yours is seeing the end too.
Regards, GeorgeK
[This message has been edited by GeorgeK (edited 11-05-2001).]
Old 11-05-2001, 12:43 AM
stray15's Avatar
Send a message via AIM to stray15
Post
Why are you guys ruling out the CV's? That would be my first guess.
Old 11-05-2001, 06:09 AM
thamlin000's Avatar
Post
My CV joint went out recently. Symptoms: clanking from the rear, intensify in volume at WOT, sound only when accellerating between 1-35 mph and decellerating 35-1 mph.
Old 11-05-2001, 08:49 AM
RaF944's Avatar
Post
The Wrench said its the CV joints... so he said he will rotate them and it will cost as much as 1 new one
85.5 Porsche 944
Old 11-05-2001, 02:25 PM
Ven Ven is offline
Post
Just get some rebuild kits for your CV joints. 60 some dollars a pop. Swapping them out will only buy you some time and then you have to pay the wrench even more money to put the new ones in.
Old 11-05-2001, 03:00 PM
Post
What about an out-of-round wheel?
Old 11-05-2001, 04:25 PM
