-   -   Post your to-do lists. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/152673-post-your-do-lists.html)
pearldrum 03-09-2004 03:28 PM
Obviously there are hundreds of things many of us want to do to our cars, but what are the things you actually plan on getting done before or maybe during summer? I've been keeping a prioritized list this winter and have already gotten the joy of crossing off half of the items on it. So, what's on your list and why isn't it fixed already!? :D
Here's mine.
(in order of priority)
1. Fix Horns (need parts)
2. Fix Reverse lights (have parts, need to pull them off other car)
3. Replace Rear passenger bearings (too cold now)
4. Replace speedo cable (I'm lazy)
5. Passenger window switch-window won't go down (not important enough right now)
6. Seat upholstery/E-brake switch ($$$)
7. Clutch (car is still able to move)
8. CV joints (optional)
9. Refinish wheels (not enough time right now)
10.Rebuild engine ($$$$$$$$$$$$$$$$$$$$$$$$)
will944 03-09-2004 03:32 PM
1) Sell old 944....guess I should post that on the FS forum ($1500)
2) Enjoy maintenance free 951 for as long as possible
3) Buy MAF, Exhaust, Intercooler Piping, etc etc for 951 when I get some cash!!
SoCal Driver 03-09-2004 03:37 PM
Jack up radiator cap and drive 951 under it.
UconnTim97 03-09-2004 04:03 PM
I just finished most of mine in the last few weeks:
Tinted windows and fixed rear hatch leak
Installed new carpet
New speakers
Throttle response cam
Fixed parking brake
Changed oil and filters
repaired rear wiper
Realigned headlights
Things I have left:
New antenna (arrived today)
Replace center cap that has a chip in it (also arrived today)
88_944 03-09-2004 04:11 PM
Well the car is runing great so I'm just doing some other things. I just won some Blue H3 6000K foglight bulbs and 2 pairs of Blaupunkt PCx462 Coaxial 4"x6" Speakers both new on Ebay and waiting for it to arrive.
The H3 6000K foglight bulbs should be this bright.
http://images.auctionworks.com/hi/61/60728/i-2.jpg
The next thing I'm buying is a RRC6024 Flat Glass Composite headlight Conversion Kit. It's using a KRYPTON/XENON HID Bulbs with 4300K Color.
http://ebay.racingr.com/RRC6024_Pic1.jpg
pearldrum 03-09-2004 04:17 PM
I've been considering getting some brighter foglight bulbs. Let me know how they compare to the old ones when you get them installed.
88_944 03-09-2004 04:24 PM
Sure thing.
On the sellers page of those H3 6000K foglight bulbs, He has this picture sample. I should have the bulbs by Saturday.
http://images.auctionworks.com/hi/61/60728/new_blu.jpg
He has more for sale.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=36476&item=2465733 860
will944 03-09-2004 04:54 PM
New speakers
How did you replace the rear speakers?? Or did you just replace the fronts?
I have a set sitting in my garage....just don't want to tackle it bcz I don't know the easiest way.
Also...how much was the tint? And how did the rear hatch end up....I understand that is the most difficult part
chapstic2001 03-09-2004 05:08 PM
Man, you read my mind on the idea of a thread topic. Here is my "re" list:
-repair cut in brake wear sensor line
-repaint (thinking of going to arctic silver)
-remove engine and replace all seals, gaskets, bearings etc...(ok fine, it will be a rebuild.)
-replace button on my heater control unit.
-rethread steering wheel or replace it.
-install dual port waste gate and new BOV
-replace all vaccum and water hoses
-replace bushings on the suspension anti-sway bars
-rebuild rear breaks due to lazy PO.
schlag 03-09-2004 05:15 PM
* Shifter bushings to fix loose shifter
* Alignment - its a bit off.
* Replace clunking front brakes / rotors
* Patch exhaust leak
* Body work, paint job
I'm proud that my list is really pared down lately.
pearldrum 03-09-2004 05:28 PM
You're thinking of going arctic silver?
I did...
http://forums.pelicanparts.com/uploa...1078882081.jpg
http://forums.pelicanparts.com/uploa...1078882096.jpg
Sabyre 03-09-2004 05:33 PM
Those lights are blue tinted. Actually I have that whole kit bulbs included if anyone is interested in purchasing. BTW the lenses in that kit are NOT DOT approved. FYI.
I changed em out for Sylvania Silverstar 6024t. Very happy with em.
AFJuvat 03-09-2004 05:43 PM
To Do:
Replace oil pan gasket & cam tower gasket.
Reseal front (not needed, but since I am going to have it al lapart anyways)
Replace AC compressor (clutch went south on it)
AFJuvat
schlag 03-09-2004 05:57 PM
Arctic silver is pretty!
TCMdocs944 03-09-2004 06:34 PM
Partial:
Track down oil leak post seal job
New tires
refinish rims /or
New rims
One dashlight fix didn't take...redo
Blackfoot 03-09-2004 06:49 PM
1) Remove grass on side of driveway, replace with some sort of tile so I can park 3 wide.
2) Sell 968
3) Sell 928
4) Get a job
5) Justify having a 600+ hp beast. So far I have been unsuccessful.
6) Get a job
7) Upgrade car insurance
8) Get a job
9) Dream about having a lift
10) Paint garage floor with gray epoxy
_______________________
Cars
Macfreak007 03-09-2004 07:28 PM
Mine is getting rather large as you know Tyler....
1. SUSPENSION, new front koni inserts, new mounts, new springs, and a new housing
2. Brakes, swapping brand new stuff of my parts car and bleeding them
3. fixing my quarter panel
4. Painting the whole car, myself, :)
5. Right front wheel bearing, probably just do them all
6. motor mounts
7. Finish refinishing my fuchs, front are done!, and look great!!!!
8. get a spare tire
9. find out where my oil is all going
10. prepare for my first timingbelt/ waterpump job
11. If I have sucessfully reached this step with out emptying my bank account then I will be fully satisfied, time to go out and enjoy my perfect car
UconnTim97 03-09-2004 07:31 PM
I took the easy way out and only replaced the front speakers. The back speakers are fine for now. I will have to replace them eventually....I keep it faded mostly to the front. I am happy with just having good quality sound.
I paid $300 for the tint. It took about 6 hours for him to get the rear window right with one piece. I had to go back the next week to have a few bubbles removed once everything dried. Looks great now.
I had lower quotes for the tint, but I had seen this guys work before, and he came highly recommended. I felt the car deserved having it done right.
ronin 03-09-2004 07:54 PM
still far and away my favorite
Brando 03-09-2004 08:12 PM
1) Get another 944...
fast924S 03-09-2004 08:39 PM
1. Install new tranny- been to lazy
2. Sell 17" turbo twist rims with tires $1500
3. Find new rims and tires
4. Repaint car
5. Get a new High performance CAM
6. Get a chip- in the works
7. Install high flow cat- agian been lazy
8. Upgrade suspension
Not really in this order but those are the things on the to do list.
Porsche-O-Phile 03-09-2004 08:41 PM
To do. . . hmmm. . .
1. Get an E2 and enjoy smoking all the ricers / M5s out here :D
Oh wait, there's that $100K+ price tag thing isn't there. . .
OK then:
1. New tires
2. A/C compressor & hose replacement & charge-up
3. Replace rear hatch "pins" so hatch will sit level (parts came in today!)
3. Some little stuff (3rd brake light kit, fuel filter change)
4. Replace rear deck carpeting (no leaks from rear hatch now)
5. Replace torn seats (new ones should show up next week so I'm told)
6. Swepco in the tranny
7. Check / repair cruise control computer if necessary
8. Replace all belts / seals / rollers & H2O pump in a month or so. . . Just had 'em tensioned but they're getting old.
9. New paint job
More-or-less in that order to get a "new" Phat-looking and mechanically excellent early 944 out of my beast.
Then get a 951 to keep it company and somehow convincing the wife to not castrate me with a rusty knife!
ntrylvl 03-09-2004 08:41 PM
I just replaced my rear speakers - requires taking the windows out. Stock speakers are 4x6's, but--surprise--there is space to upgrade to 6-inchers without cutting. Huge difference in sound quality, especially low/mid-end.
My to-do list:
Replace 2 bent wheels :mad:
Charge A/C (it's only March and 80+ degrees today)
Stop rear hatch from rattling (perfection not needed - will settle for progress)
Repair numerous small door dings
Upgrade to 968
UconnTim97 03-09-2004 09:08 PM
Clarks has a good procedure for repairing the rear hatch. Did mine a short while ago,
http://www.clarks-garage.com/
ntrylvl 03-09-2004 09:22 PM
Thanks, Uconn. Have printed the procedure for reference!
UconnTim97 03-09-2004 09:51 PM
No problem, glad I could help
1.2gees 03-10-2004 01:08 AM
Blackfoot, what's wrong w/the 968, how much?
My to do list:
Replace head gasket
Don't run 18lbs of boost on 89 octane gas and go through the gears at full boost on warm day...
Ahmet
Blackfoot 03-10-2004 01:13 AM
Nothing's wrong with the 968. $11.8k for Pelicanheads. You in the market?
___________________
Cars
Nabeel 03-10-2004 02:03 AM
- Fix damn dent that has been on my car forever (first had to wait until I saved up the money, then had to wait until the weather got nice and warm. I don't drive my car much in winter, thought it was pointless to fix it until I could actually drive the thing on a regular basis again)
- Unjam the cd changer and get back 12 of my favorite CDs stuck inside
- New stereo. Still have the stock system, with a 12-disc changer added by PO.
- Get new tires. Currently have quite a bit of tread left on the current tires, but I hate 'em.
Mechanically, my car seems to be very solid w/ no probs (knock on wood...)
toolboy62 03-10-2004 04:27 AM
my list...
1) replace gauge cluster with the one that just came yesterday so my odo will work
2) replace the dash backlights at the same time
3) fix cruise control if it still works intermittently after above
4) new motor mounts
5) repair rust around edges of driver's side quarter panel (looks like it was replaced, and not sealed properly)
6) reseal driver's side taillight at same time
7) get stock chip from PO so I don't have to run expen$ive premium gas
8) get new driver's side seat cover from PO and fix power seat functions at same time
wow, that is a long list... :(
nate
Rot 911 03-10-2004 06:34 AM
I know it's a 911, but here is what I have done since last November:
1. Complete tear down and engine rebuild.
2. Backdate heat system.
3. Rebuild rear suspension and replace rear wheel bearings.
4. Remove rear bumper pads and repaint rear bumper.
Z-man 03-10-2004 06:46 AM
Originally posted by TCMdocs944
...One dashlight fix didn't take...redo
Welcome to the 'dark dash' club! I've taken my dash apart three times now, and still don't have dash lights! I've resorted to using a blue neon Bling! Bling! light bar I bought in K-Mart for now...
So, here's what I've marked off the list last month:
1. New rotors & machined out calipers.
2. New front turn signal lenses
3. New front fog light trim pieces.
On to my 'still need to do' list:
1. Fix those stupid $%^#$ dashlights!
2. Replace rear speakers (got new ones -- just need to put them in!)
3. Take out radio/cd unit and fix loose connection.
4. Give my car a good detailing.
5. Paint the rest of my track wheels
6. Learn to drive faster! :D
7. Clean and paint my garage.
That's about it...
- Z.
toolboy62 03-10-2004 07:07 AM
I just wish someone could tell me what those bulbs are supposed to be. I have 1.5W bulbs in there now, but it looks like a W3W (3W) or W5W (5W) bulb would be a direct replacement... not sure which would be closer to the brightness of the heater controls etc. Also I have no idea what the stock bulbs, a W3W or W5W is actually listed as at an American parts store... (i.e. Mazda number)
nate
1.2gees 03-10-2004 07:16 AM
Blackfoot, I can be for the right car though I hadn't planned on it quite yet, and I think I'm looking for a broken one... You wanna e-mail me some details/pictures?
Ahmet
Z-man 03-10-2004 07:17 AM
nate
Your bulbs may not be the problem: I have a short on the circuit board that it very. very difficult to hunt down.
-Z.
jts924s 03-10-2004 07:39 AM
1) find missing WMD
2) develop cure for West Nile Virus
3) move to California, run for Govenor
4) learn to hit golf ball straight
-- See how much time I have on my hands now that the Porsche is gone.
TCMdocs944 03-10-2004 08:20 AM
Dash bulbs can be best procured by removing them, going to NAPA and asking for replacements. They pull keep trying until they get it right.
Yes NAPA....Not NASA... although it is almost that difficult.
The problem is that the lights are really picky about how they want to sit in the early "holders". This will be the third time I go in there.
pearldrum 03-10-2004 08:33 AM
I've been lucky and my dash bulbs have been okay. They aren't super bright, but I can see the guages at night.
Lawrence Coppari 03-10-2004 08:48 AM
Second or larger oil cooler.
CJFusco 03-10-2004 09:01 AM
well now that I took care of some suspension and brake upgrades, my to-do list reads:
1)Tires
2)Sunroof trim
3)FRWilk chip
4)Swaybars?
