How many of you run synthetic?
Considering changing the oil on my 944 just because I don't know when it was last changed... filter looks fairly new, oil looks clean, but who *really* knows? Anyway, here's the problem. Around here a gallon of Shell Rotella 15W40 goes for about $6 and change. A *quart* of Mobil 1 15W50 is about $4.50. So you see there's a significant cost hit in using synthetic in a car that takes seven quarts of oil...
This is just a daily driver, not abused, about 110K miles (est. - odo is busted) and I live in a fairly mild climate. I figure that the conventional oil changed at 3K will still save me money over the synth even if I stretch it to 6K or 7K miles. any input appreciated. nate
1988 944... and a bunch of other cars
Feelin' Solexy
I'm running mobil 1 0w40, I love it.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
my friend/mechanic suggests castrol gtx in a 15w40(i think). he also suggested a synthetic for your tranny fluid too.
85.5 944n/a 77 924 SOLD 2004 Dodge SRT-4 |
mobil 1 15w50, was running 0w40. too thin for a turbo.
1986 951 1995 M3 LTW 1995 Esprit S4s 2015 328d |
20-50-castrol gtx, more often than necessary
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Definately run synthetic.
I was using Mobil 1 5/10W-30 depending on the season. However, when I get everything back together, it's getting filled with Amsoil from now on. I am very impressed with their products.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
Mobil syn. 10W-30 but might be switching to 15W-50.
IS ANYONE USING MOBIL SYNTHETIC TRANNY FLUID? - (Is it worth switching over to?) - 1980 931 and now the motor is being rebuilt for 5K Last edited by WhiteRaven530; 03-11-2004 at 05:35 PM.. |
10w30 regular oil....
2007 997 TT 1992 500e |
What do you guys think of Pennzoil, either conventional or Synthetic? I get oil changes for $10 no matter which one or weight I use.
Should I run the Pennzoil or spend more for something else? Should be picking up the car tomorrow after school...:-D |
WHILE I RUN MOTOR OIL IN THE ENGINE, I KEEP A QUART OF MAZOLA IN THE Back seat as a conversation piece, should the topic arise.
p.ps. why are the keys all mixed up on the keyboard, and why did i have to learn them in order,....in a song?????????????? ditd the nuns/nuts have that much power?????????????
Here is one source out of many to look at for why to switch to synthetic.
http://www.mr2.com/TEXT/synth_oil.txt |
ok, i am convinced. i am going to switch my 350 tbi 1 ton boxter van to it, and pull my 6700 pound trailer 150 miles. hpoe the turbo 400 cAN TAKE IT. SHOULD CHANGE ITT ALSO.
TOM
toolboy. I noticed your in Bowie MD. Im down in St. Marys (leonardtown to be exact) and i have a busted up 944 that im parting out. Let me know if you ever need a part and ill let you run down and get it. (as long as its still there)
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
I heard that synthetic oil in engines with old gaskets and whatnot can be bad, but i don't really know anything about that.
but i do run the mobil 1 synthetic tranny oil. I still need to fix the sloppy linkage wear problem, but i've noticed a difference already.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
vott does ziss do?
Castrol 20-50 dino
Yes, I use synthetic in everything I have except the Ferguson 135, and this includes a pair of Ford 427 (Chris Craft) marine engines.
I use Mobil-1 15W50 in everything, but tend to lean toward the 10W30 in cold weather for top off. Any of you guys still running dino, take a look at the following link and see how your oil stacks up against Mobil-1. You'll note their 15W50 flows down to colder temps than some 5-weights, so it's some pretty awesome stuff. I think Amsoil Series 2000 20W50 is a better product, but much more expensive. I absolutely love their (Amsoil) Series 2000 75W90 gear lube, as it quieted my 165,000 mile 944 transaxle down nicely, and it shifts better too. Check this out (and weep, unless you're using synthetic) http://www.ac427.com/html/cobra_32.shtml P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet My other car is a Chris Craft Commander http://www.chriscraftcommander.com |
Official Sponsor
I use Mobil 1 10 -30, all my mechanic friends use it in their cars...
anybody tried the synthetic ATF?
1988 - 924S Guards red, auto trans |
Castrol 20W-50W
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
I use synthetic ATF in the power steering. Mobil 1.
I put Amsoil 2000 series 75-90 in my gearbox, and it's just wonderful down to -35C, shifts like a whole new transmission. However, at -35C it stiffens up so hard it takes 2 hands to get it in gear, and full throttle just to coax the car along. Let off the gas and the tires screech it slows down so hard. Takes a good 10-15 mins of warming up at below -35C before it's drivable. However, I would imagine most oils do that, so thumbs up for Amsoil. Just for clarification, I believe the best Amsoil motor oil is the series 3000? Or perhaps I am crazy. But yep, it does cost, about $13/Litre CDN.
Is amsoil really better than mobil 1 synth? If so, is it worth the extra cost?
991.1 RS - Lava Orange 991.1 GT3 - Sapphire Blue - gone 997.2 GT3 - Guards Red - gone 996 GT3 4 Liter - Basalt Black - gone |
