Send a message via AIM to TheCooler
Rebuilding my engine
Im on my way with dropping it now and I think its time to order parts. So far the tab is $739.50!! This is what Im getting so far.
Head Gasket Set
Main Engine Bearing Set, Std
Crankcase Gasket Set
Rod Nuts (I have bearings already but I need to see if I can trade std in for oversize.)
Front Engine Reseal Kit (should I buy all the rollers and stuff to or just check to see if they are in good condition and no playin the bearings?)
Balance Shaft Belt
Timing Belt
Alternator and A/C Belt
Power Steering Belt
Wrist Pin Bushing
Piston Set, Standard
Mahle Oil Filter
Thermostat
Do i need to get a new Oil pressure relief vavle?? Someone said i needed to get it for the head and in the engine.
What else should i get/need?
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 04-09-2004, 10:39 AM
SoCal Driver's Avatar
If your engine has the seperate spring and piston oil pressure regulator you should buy the newer one piece unit. A bit expensive but eliminates the sticking that the older ones tend to do.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-09-2004, 10:41 AM
I assume it has the one peice one since its a 89...I hope.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 04-09-2004, 12:50 PM
