fast924S's Avatar
Send a message via AIM to fast924S
TPS sensor
does anyone know what each wire is for on the throttle body sensor, I have a 1987 924S, IF you could tell me the color of the wire and what it does it would be very helpfull, Im trying to find out if there is a 5 volt reference wire. Thanx
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 04-19-2004, 08:36 PM
SoCal Driver's Avatar
Throttle position switch(s). Two. One for idle and one for wide open throttle.
N.C. / Idle
Connector pin 1 white/black to DME pin 2
Connector pin 2 brown to ground at DME
N.O. / WOT
Connector pin 3 white to DME pin 3
Don't know what voltage they use.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-19-2004, 10:18 PM
