Question New top end sound getting louder
I need your expert advice please.
When I start my S2 I am now getting a strange top-end noise from around the cylinder head towards No.4 cylinder.
It started by making a tinkle noise then a rattle and now it is making a clack.....clack.....clack.....clack.....clack..... clack.....clack.....noise.
It is getting louder every time I start the car.
Do you think it could be the camshaft tensioner (kettenspanner 944 105 049 01)
I do not want to run the engine too long in case it is causing damage, but I am asking myself if it is not the
hydraulic tappets due to low oil pressure because the car has been standing.
What do you think?
Many thanks,
Philippe
Old 04-23-2004, 10:36 AM
SoCal Driver's Avatar
Pull the valve cover and take a hard look! Might be the tensioner. Might be a loose cam bearing block. Might be a broken cam.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-23-2004, 11:47 AM
