Damn i hate this starter motor.
This thing is about 10 months old (its a rebuilt) and its been grinding occasionally. I took it off tonight no debris near the fywheel. the flywheel teeth i can see look fine (likewise for the starter motor teeth) Could this be a bad switch in the starter motor that i could replace? Also, i noticed a fair amount of gunk in the starter motor. Could a leaky rear main be leaking on the starter motor causing it to slip? If i have broken flywheel teeth, i would be able to see them, right? Any suggestions are welcome
84 944 Non Alcoholic |
You'll have to spin the motor around to check for missing teeth on the flywheel.
Chances are, you have a bad bearing in the starter - will mean another rebuild AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Dang.
Can i damage the flywheel with the starter motor grinding like that? Does anyone have a starter motor diagram? I think i might take it apart tomorrow
