TCMdocs944's Avatar
Spacer nuts - size and source?
Just got a great deal on a pair of 2" spacers for my new boxter wheels. They were from a guy in Tampa with a 84' 911. Seem to be unused.
These are the type that have the lugs already attached and you bolt them onto your existing lugs.
They came with no nuts for attachement.
What do I use?
Where do I get them?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 05-18-2004, 02:37 PM
Re: Spacer nuts - size and source?
Originally posted by TCMdocs944
Just got a great deal on a pair of 2" spacers for my new boxter wheels. These are the type that have the lugs already attached and you bolt them onto your existing lugs.
What do I use?
I'm in the same boat. Are the threads similar to another car ???
Mark
'86 944NA
Old 05-18-2004, 07:15 PM
Used & Abused
Steel lug nuts, perhaps? They aren't capped so you should be able to thread them through.
He wouldn't happen to have another set of spacers, would he?
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 05-18-2004, 08:48 PM
Use Porsche steel wheel nuts to hold the spacer to the hub, use Porsche alloy nuts to hold the wheel to the hub, Use a torque wrench!!!
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 05-18-2004, 09:36 PM
TCMdocs944's Avatar
Alway use my torque wrench.
Mlue...uuhhhh...the treads are the same as all the others on your car.
idontknow......I might be aquireing another set of 2" spacers very soon...I will let you know.
Brit....thanks as always.
? Anyone got a good source for new or used Porsche steel wheel nuts??
none at pelican and tweek$$$ well you know tweek$$$
Old 05-19-2004, 07:12 AM
TCMdocs944's Avatar
Oooopppss,
My mistake.
Pelican and paragonproducts both have them.
Pelican is cheaper by over $5.00 when you include shipping. 10 for about $17.
http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&mh=20&view_records=yes&uid=default&description=lug+nut&nh=2
Thanks for the help. I will post pics of before and after, of course.
Old 05-19-2004, 07:26 AM
Used & Abused
Thanks, keep me informed.
What else do you doing to get the boxter rims to fit?
Old 05-20-2004, 04:10 AM
TCMdocs944's Avatar
Nothing.
Boxter rims bolt right up with spacers.
Without you have to grind down the front dustcaps about 1/8th inch. They look ok like this but not really custom, which is what I am going for .....like Ruf or Gemballa etc.
For a really good look I like bringing the tires out to the wells.
This sounds complicated but this weekend I will..
Jackstand whole car
Pull all wheels
Clean all wells and undercoat
Paint all brake calipers
...heres the wheel part....
Move my front lugs to the rear and my rear lugs to the front.
move my rear stock spacer to the front and bolt wheel on
Put the 2"spacers on the rear and bolt wheel on.
Oh yeh, change r Rear wheel bearing while I'm at it.
Will Post before and after pics
Old 05-20-2004, 07:04 AM
