Spacer nuts - size and source?
Just got a great deal on a pair of 2" spacers for my new boxter wheels. They were from a guy in Tampa with a 84' 911. Seem to be unused.
These are the type that have the lugs already attached and you bolt them onto your existing lugs. They came with no nuts for attachement. What do I use? Where do I get them?
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Re: Spacer nuts - size and source?
Mark '86 944NA |
Used & Abused
Steel lug nuts, perhaps? They aren't capped so you should be able to thread them through.
He wouldn't happen to have another set of spacers, would he?
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
Use Porsche steel wheel nuts to hold the spacer to the hub, use Porsche alloy nuts to hold the wheel to the hub, Use a torque wrench!!!
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Alway use my torque wrench.
Mlue...uuhhhh...the treads are the same as all the others on your car. idontknow......I might be aquireing another set of 2" spacers very soon...I will let you know. Brit....thanks as always. ? Anyone got a good source for new or used Porsche steel wheel nuts?? none at pelican and tweek$$$ well you know tweek$$$
Oooopppss,
My mistake. Pelican and paragonproducts both have them. Pelican is cheaper by over $5.00 when you include shipping. 10 for about $17. http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&mh=20&view_records=yes&uid=default&description=lug+nut&nh=2 Thanks for the help. I will post pics of before and after, of course.
Used & Abused
Thanks, keep me informed.
What else do you doing to get the boxter rims to fit?
Nothing.
Boxter rims bolt right up with spacers. Without you have to grind down the front dustcaps about 1/8th inch. They look ok like this but not really custom, which is what I am going for .....like Ruf or Gemballa etc. For a really good look I like bringing the tires out to the wells. This sounds complicated but this weekend I will.. Jackstand whole car Pull all wheels Clean all wells and undercoat Paint all brake calipers ...heres the wheel part.... Move my front lugs to the rear and my rear lugs to the front. move my rear stock spacer to the front and bolt wheel on Put the 2"spacers on the rear and bolt wheel on. Oh yeh, change r Rear wheel bearing while I'm at it. Will Post before and after pics
