Electronic speed sensor, do they make?
I want to know if they make an electronic speed sensor for out cars. I know that Autometer has a sender for some transmissions which is supposed to work
http://hp.autometer.com/products/accessories/prog_speedo_sender/prog_speedo_sender.html
but wil this work with out cars? Just wondering.
Thanks,
Shawn
1984 Porsche 944 na
Black on Black leather
Digital Dash
Auto dimming rear view mirror
Enkei 15x7's
Fog/headlight mod to come
AIM - ShawnMacAnanny
Old 05-18-2004, 08:28 PM
Don 944 LA's Avatar
I have an electronic Speed sensor in mine...
its called a GPS !!!!
Magellan Map 410
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 05-18-2004, 08:54 PM
Um i don't know anything about gps, but is it an actually speed sensor based on tri positioning, or is it just a map extra and not in the actual cluster?
1984 Porsche 944 na
Digital Dash
Enkei 15x7's
Old 05-18-2004, 08:58 PM
Used & Abused
GPS = Global Positioning System Works on satelites in orbit to calculate your position direction, and altitude.
You may need to pick up an 85.5+ tranny. I believe you would have to drill, tap, and clean the older tranny to fit the speed sensor. The later tranny has the speed sensor around the differential area.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 05-18-2004, 09:22 PM
Hehe yeah that's what i meant about the GPS. Well no that's not what i meant but i knew that. i was thinking of using seismegraphs to tripoint epicenter locations during earthquakes. Silly me Will an 85.5+ fit that? My car has an LSD tranny i dunno if they came with it on not. I know the person mentioned something about it needing to be replaced beause of clunking i heard when driving it, but i don't hear anything now.
I'm pretty sure it's an LSD trans. I will jack it up tomorrow and see. In my dirt driveway i can drop the clutch and it will spin both wheels at the same speed, in the grass the same, when drifting in the grass the same, and when spinning in reverse the same. Does this make it an LSD? What if my speed sensor is mounted on the wheel? I haven't thought to check yet while doing all this stupid stuff i know rpms go way up in gear, but i haven't look at speed. I'll let you know tomorrow. I thought LSD trans only came in later models though.
1984 Porsche 944 na
Digital Dash
Enkei 15x7's
Old 05-18-2004, 09:37 PM
SoCal Driver's Avatar
Your speedometer comes off of the left front wheel via cable.
Some have used the sensor fins on the rotors for the ABS. But you would need a later car.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-18-2004, 11:48 PM
Used & Abused
LSD was a factory option, some had it, some not. You'll have to do the jack up the rear trick to find out. I can spin both tires as well, what counts is when you're turning, the inside wheel would spin while the outside wheel played dead.
EDIT: You'll need to calibrate the speedometer, but yeah, it'll work.
Old 05-18-2004, 11:52 PM
