I've been seriously debating the lt-1 conversion for my 944 NA. My only worry about it is the transaxle. I've heard that the NA transaxle is only rated for around 200 or less HP and the turbo trans is rated at 350 or less. But what if I intend to get more than that out of my lt-1. It's very possible that I would. What could I do to make the trans withstand that much pressure? or what trans would be the best to get for the job that will handle 400+ ponies?
1986 944 non-turbo |
Honey Badger
The Camaro trans that fits real good in a CAMARO (or other GM POS) will handle 400+. Other than that 951 trannies have been known to support 400+.
If you want a LT-1 buy a car that has one. You knew this was coming right?
1978 911SC 1953 Piper PA-18A USAF EOmfD |
75 914 - Undecided. 80 931 - Gone, but not forgotten. 72 914 - old toy- sold. And a whole bunch of German scrap metal shaped like 924's. Old enough to know better, and stupid enough to do it anyway! |
Honey Badger
Is that complete with the roll of tape on the throttle-body?
Yee Haw I so, sign me up!!!
And don't forget these!
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
SoCal: Those free floating strut plate bolts are part of the upgrade.
so is this:
84 944 Non Alcoholic |
Dog-faced pony soldier
Yea, but can I turbo it? It's only an n/a after all. . .
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
You mean nobody noticed the lack of headers???? No its not complete, a project.
And yes, you can turbo it!!!!!!! You wanna be caught driving aroung with only 425hp...
Non Compos Mentis
Lack of headers?
That's a free- flow exhaust. Makes the car lighter, too. |
I guess a 951 wasn't fast enough? With the money put into that conversion from a 951, the owner could have easily bought kit that makes the same amount of hp without destroying a beautiful car. What a waste.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses www.apartabove.com |
I would rather drive a twin turbo ZO6.
Yummmy ![]() Uhmmm and the conversions also dont use the brake booster... go figure..
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Even 944s want V8s under their hood
My car asked me if I'd swap an LS1 in the engine bay when the 2.5 dies. I told her I'd think about it.
The present: 83 944, 77 911S The past: 95 911, 67 912, 76 912E |
My car asked me the same thing.....I threatened to pull her DME if she ever asked a stupid question again...
My turbo asked me the same thing!
and I said "BLOW ME"
Did the S2 trannies get the hardened gear treatment that some of the turbo trannies got? If so, I would think that would be the way to go.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work. Malo periculosam, libertatem quam quietam servitutem. |
My car is just happy I saved her from an undeserving P.O.
![]() She loves me.
in all seriousness guys c'mon....i didn't ask for the ridiculing comments. I was just wondering what would be the best transaxle to put in the car. I the turbo tranny will handle well over 400 HP then that will probably be the one that i go with.
Thanks silver 944....i figured somebody would say that, but can the camaro's handle like a 944? I want a car the will handle like a dream and still have bragging rights on the straight aways. Camaro's and Corvette's...everybody knows somebody with 1. 944's are something desired to own and i'm just trying to make it the dream car to drive that it deserves to be *tear*.
TUrbo tranny is your best bet. They can easily handle 400rwhp cars on sustained track use. The abuse of dropping the clutch and hammering through the gears is what does them in.
