Bouncing Speedometer- How to fix?
'86 NA... My speedo sometimes works: fine/bounces/not at all. Could it be the cable or hall sensor or the guage itself? Waht is most likely the problem? Coincidentally my odometer doesn't work but that is surely the plastic gear. Thanks...
Old 07-06-2004, 12:41 PM
new speedo cable probably.
But check the seat on the back of the gauge first before you by a cable.
There not cheap.
Current: 1973 914/4 project. FOR SALE
Old 07-06-2004, 01:07 PM
$30 for a cable here at Pelican> I wouldn't call that expensive. What about the speedometer impulse sender? Could that cause an intermittent problem? Thanks!
'86 Guards NA 70K- driving 11yrs
'98 Techno-Violet M3 57K- since 4/04
'55 MiG-15 UTI - Mach.97 -rebuilding
'58 Cessna 175 w/GO-300
'98 Scarab Sprint, 4.3V, 62mph
'92 Guards 968 (my girlfriend's)
Gone...
'82 Camaro Z28 1st car
'84 VW Rabbit Cabrio & GTI
'77 BMW 630 4spd sport bilstiens
'84 POS Cavalier- drove to junk yard
Old 07-06-2004, 01:52 PM
not sure there.....
I guess I got lucky.
$30 isnt bad. I think I paid $75 for mine at a local shop.
Old 07-06-2004, 01:59 PM
mikemurcia's Avatar
The late (like your '86) 944 speedo is not cable driven. There is a sensor on the tranny that picks up your speed. If the car in question is truly an '86, there is no speedo cable.
Old 07-06-2004, 02:20 PM
Send a message via Yahoo to Cebu
It is most likely the speed sensor on the transaxle
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 07-06-2004, 05:56 PM
Sorry man, Forgot i did it on the early 944.
Old 07-06-2004, 06:31 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
how about on my 88 924S, the 924Ss are the same as early 944s right? if so mine would be a cable.... if im right...
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 07-06-2004, 08:54 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Yes, the 924S uses a cable as well.
PS: If you don't mind an extra long cable, a lot of VW cables will fit. If the bouncing is extreme, the problem is likely internal to the speedo.
Ahmet
Cheers!
Old 07-07-2004, 01:48 AM
The bouncing is not extreme. It does not peg to the max side, usually just past the actual speed and then down to zero. Which sensor are you describing, the hall sensor or the impulse sender? BTW, the car is a 1986 MY. Thanks guys!
Gone...
Old 07-07-2004, 06:41 AM
The Speed sensor/sending unit is located above the left rear wheel drive axle where it attaches to the transaxle. Has an electrical plugged into the sensor or sending unit.
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 07-07-2004, 11:15 AM
Send a message via AIM to Trevor
Mine will sometimes stick at 0 then catch back up after a few seconds. Does that mean something is wrong with the sensors or is it most likely the guage?
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 07-07-2004, 11:19 AM
Trevor, mine is doing the same thing. I think this is what we need to replace, "speedometer impulse sender", right guys?
http://www.pelicanparts.com/catalog/images/electrical/94460621000.JPG
part # E-606-210-00 ($54.25 at Pelican)
Gone...
Old 07-07-2004, 11:28 AM
I think I can live with it....
96' Jetta (RIP)
1986 N/A (Sold)
1993 325is
Old 07-07-2004, 03:05 PM
bull4u2me's Avatar
my speedo/odo stopped working. A mechanic suggested replacing the impulse sender.
Heres a list things of what could have gone wrong....
1) the impulse transmitter
2) the wiring/clips along the whole speedo setup, from the transmitter to the instrument cluster
3) the speedo cluster itself (which I hear, very rarely screws up),however you can purchase a second hand one on ebay for around 150$.
4) there could be a problem inside the transmission itself (where the sensor is attached to).
I guess there could be more places things could go wrong, but from what I hear, its usually the transmitter that quits first.
Till then the only way to judge my speed is with the rev meter (with the 3 speed auto its rev X 2 = approx speed in mph).
So Cal... is there a way I could test the speedometer cluster myself?
~85.5 Bronze Beauty! (944 N/a Auto)
Old 07-07-2004, 03:10 PM
